Question about Eemax SP3012 3.0kW 120V
Eemax model SP-3012 not heating water. I can hear a reley "click" but water is not getting hot at all. I have roughly 50 (fifty) units that have these water heaters and they are about 2 (two) years old. 7 (Seven) of these units do not get hot and I believe it is the element.I need to purchase these elements (if that what it is) and I don't know where to get them locally. My zip code is 32137,Can you tell me if in fact it is the element and where to purchase them. Eventually I will need more.
  • 70 Answers
SOURCE: my eemax ex120tc 11.5kw 240v the water does not get hot enough.
you can check elements with a meter to see if they are any good. how old is heater?
Posted on Feb 09, 2009
dragonsthatk
  • 547 Answers
SOURCE: no hot water
in and out hooked up right?
Posted on May 17, 2009
SOURCE: TWO HEATING ELEMENTS WONT TURN ON LIGHTS SHOWING
to what
Posted on Dec 18, 2009
SOURCE: trips breaker
If it trips the breaker you MUST have an Earth fault and or a short circuit to Neutral/Earth. You must get a Registered Electrician to look at it.
Posted on Feb 03, 2010
  • 65 Answers
SOURCE: I just installed the newer
Call the rep!
Posted on Jan 31, 2011
I have a Eemax so 35 instant water heater and it makes a buzzing noise when you turn the hot water on
Heavy current required for instant hot water may be switched via a relay or contacter which may be faling. One way to diagnose may be with cover off and careful listening and visual inspection, but a risky process for inexperienced DIY'er's ??. Pro time?
Apr 11, 2017 | Eemax Water Heaters
How do you adjust the temperature on a model SP 3512
Check if thers incoming water. Ur heater dependent on the level of water
Sep 15, 2014 | Eemax Instant Water Heater 120V SP3512
My water is too hot eemax sp 90
Water heaters have thermostats so that you cand adjust the temperature of the water. Temperatures above 120 degrees can pose a scald hazard.
Jul 15, 2014 | Water Heaters
Eemax280t2t no hot water
see if the circuit breaker switch has tripped either partially or fully and reset it. Check for bad or loose wiring on the heater and breakers. The next thing is more likely the heating element is no good and needs repaired or the heater needs replaced.
Jan 30, 2014 | Eemax Water Heaters
Ge geospring hot water heater fault code F1
Copy following links before calling GE with model and serial number for local trained service technician.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Don't buy expensive water heaters that do not have service manuals available.
Gene
h
Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
Fluctuating water temp. It is hot when I start the shower,
Iam guessing your using it faster than it makes hot water. May need a larger unit or a second one,in the system
Apr 10, 2010 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
No hot water
May 17, 2009 | Eemax EX280T2T Series 3 Whole House...
We are currently updating or eemax heaters with the newer control
have you tried eemax.com go to customer service lititure request... they also have a tech support number... if you need more help feel free to contact us as sales@heaterup.com
Apr 11, 2009 | Eemax SP4277 Single Point Electric...
My eemax ex120tc 11.5kw 240v the water does not get hot enough.
Feb 04, 2009 | Eemax EX120TC 11.5kW 240V
Eemax SP3012 3.0kW 120V Logo
183 people viewed this question
Top Eemax Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you an Eemax Water Heater Expert? Answer questions, earn points and help others
