Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
Panasonic TV PT-61LCX65 Serial # - FSAA10347 June 2005 The TV power button turns green when I push it and it acts like it's going to turn on, but then it makes a weird sound a couple of times and it turns off. Nothing on the screen comes on and the fan is working, but after it turns off and the power light turns red, the lamp light starts flashing. We've checked all of the plug-ins and they are all fine....HELP PLEASE!
  • 927 Answers
Good Day,christie511;
It sounds like the lamp is in need of replacement. You could call a service company to replace the lamp, but it is so easy to replace the lamp ones self. So, call Panasonic and order the lamp, they will send to your home with instructions.
Three screws and your home free!
Good Luck, Big Irish.
Posted on Jul 09, 2008
MY TV HAD GREEN SPOTS AND THEN WENT BLANK. I REPLACED THE LAMP AND NOW WHEN I TURN IT ON THE POWER BUTTON BLINKS GREEN 3 TIMES AND THEN YELLOW 2 TIMES. THE SCREEN STAYS BLANK
The lamp will not fix the green spots. That is due to bad polarizers in the optic block. The lamp is only a white light. http://service.us.panasonic.com/OPERMANPDF/PT44LCX65.PDF
According to the manual you are not getting enough airflow which would explain the optic block failure. Make sure the TV has lots of space for air around it and is not inside a cabinet that would overheat it.
Sep 12, 2015 | Panasonic PT-61LCX65 61" Rear Projection...
When you trun on my panasonic PT-61LCX65 tv it makes no sounds the light blinks green. and then red and turns off. what is wrong. i have looked at the buble and it looks fine.
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
TV won't turn on when push power button red light flashes
You can unplug the tv for 1 minute and then plug it back in since you have a red light you know it is getting power, also don't plug it into a surge protector when trying this. If the tv still has a flashing red light a service center will need to repair the tv, replacing more than likely the power supply or small signal board.
May 07, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Reset tv timer pt-61lcx65 after lamp installation
MAKE SURE LAMP DOOR IS COMPLETELY CLOSED,THATS WHY POWER LIGHT FLASHES YELLOW
Jan 10, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panosonic PT-61LCX65 wont turn on, no power
Check your bulb. I had the same problem and it turned out that the bulb was shattered. At no time, did the lamp light turn on.
Jul 12, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
LAMP HOURS
Sure.
Make sure the set is off but plugged in. Hold the "volume down" button on the set while pressing the "tv/video" button on the remote (at the same time) over 5 seconds.
This is a "customer" service mode where you can't screw up the set but can get some basic info on your unit. You cannot change any internal info in this mode.
Hit the "power" button when you're done and leave set off for 10 seconds before turning back on to reset your tv.
Good luck, Mark
Jun 10, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
