Question about Sony Handycam CCD-TRV37 Camcorder
Cassete door will not stay closed
When I shut the cassette door it opens it up once it draws down to closure
    Sergeant:
    Champion:
  • 319 Answers
Unit may have jumped mechanism timing. Take in for service
Posted on Aug 01, 2008
Cassette Door open and close but tape won't go down into deck
The loader motor turns a belt to draw the tape out of the cassette. Probably needs replacing.
Jan 13, 2015 | Sony HDR-FX1000 Mini DV Camcorder
My cassetteplayeris broke but the front panel says tape unpluged it radio won't play pluged it back in few days later tharadio came back on.going down the road it swithched from radio playing back to tape...
the cage mechanism of the cassete is dropping causing it to shut the radio off ,only solution is to remove the radio and open case then jam the cage into the no casette position with a piece of wood or a folded up cardboard ,i think this will cure the problem
Feb 15, 2011 | Car Audio & Video
Freezer door opens when you shut the refrigerator door
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Sep 03, 2009 | Amana Refrigerators
Frigidaire FRT17G4BW9 doors not staying closed
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Cassete holder stays out cannot get it to close either empty or if i put cassete in it states that it is in safty mode on jvc model no gr-d240ek
Can you hear when you close the cassette compartiment that the drummotor is rotating? If not probably the flexwire from the drummotor is loose. Sometimes you can fix this but it is better to send it to an autorized repairshop
Regards,
Rob
Apr 16, 2009 | JVC Video Cameras
Aj-d200 video camera, cassette door stuck partially open. best diagnosis and/or remedy?
Partially open sounds like a mechanical problem with the cassette housing/door assembly. The door usually stays fully open or will not open at all, caused by component failure on the mechanical driver board. Check to make sure nothing is stuck in the mechanism, like a label or a broken piece from a cassette. If the door will move, but will not latch closed, the problem is most likely on th emechanical driver board.
Mar 25, 2009 | Panasonic AJ-D200 Camcorder
Door on Monogram ZIR36N won't pull closed and stay shut
The spring is actually a door closure , are the wheels that the bar closure mechanism goes through and attaches to the spring moving freely? It is entirely possible that a bin in the fridge is keeping the door open.
Nov 14, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
TV shuts off after 10 sec
TV/vcr combo units develop problems in the vcr section,what happens is the cassete assembly draws too much current then the tv senses this increase and it says NO and shuts down,you will not be able to use the vcr anyway because it has a problem and the tv will continue to shutdown until the vcr is repaired,I have seen combo units with the tv working only as long as the vcr is not use.Remove the light you have in the opening and hope the tv works fine by itself.Adding a light is not safe.I hope this inf.helps somehow.Good luck
Sep 16, 2006 | Samsung CXD2512 25 in. Combo
Sony Handycam CCD-TRV37 Camcorder Logo
165 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
