Question about Refrigerators
Hello, my Samsung RL39WBNS keeps cutting out. When I switch it back on it seems to run ok for a few seconds then cuts out and the display shows 'rd'. Can anyone tell me what could be wrong before I commit to call out fees? Thankyou, Gary
SOURCE: Samsung model SR-L38NMB refrigerator
that problem very likely is the control board. there is another brand of fridge in S.AFRICA THAT DOES THE EXACT THING OF WHICH THE BOARD HAS TO BE CHANGED.
Posted on Jul 25, 2007
SOURCE: TV cut out and stay on standby
hold the power switch in from off for 10 seconds, worked for me.
Posted on Sep 03, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave cuts out after 23 secs
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Dec 17, 2007
bobotfel
  • 236 Answers
SOURCE: hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Posted on Jan 04, 2008
  • 3 Answers
SOURCE: Problems with my samsung fridge/freezer SR-L36/SR-L39
is whisker growth like ***** hairs?
Posted on Jun 04, 2008
My dryer cuts on and then off I have by passed the thermal cutoff fuse and the door switch it will turn on when I plug it back in and run a few seconds and then cut off please help
does it run as long as you keep the start switch pushed then stop when you let go of button if so bad centrifugal switch in drive motor
Feb 20, 2015 | Dryers
Fridged cuts out
hi Joseph! your refigerator may have run out from coolant ,and the main reason to open and close is because it has a safety switch.
Feb 05, 2014 | Refrigerators
Samsung le40d503f7w only displays samsung logo on screen for a few seconds after switching on and then goes blank
have the same problem, one or more of the flourecent light bulbs in the back panel got broken, looking for a supplier who may keep these bulbs in stock, or other wise will see if i can get a used one off ebay for spares.
Jan 24, 2012 | Computers & Internet
My car was running fine yesterday, today it won't start. what could be the problem? it seems like it not getting any gas
Hello, Check for a switch in the trunk, on the drivers side. If you have Air Suspension, the switch for the fuelpump is next to it. The switch has a reset button and you press and hold it down for about 2 seconds and then release it. This should reconnect the fuelpump and allow you to start the car.
The name for this switch is the Inertia switch. Its purpose is to cut off the fuel in the event of an accident. The switch can cut off when a door or trunklid is slammed at just the right frequency to trigger this safety switch. Once reset it should run normally.
If the switch keeps cutting out, you may need to replace it. It works on magnetism and sometimes the plating on the contacts erodes and it will disengage.
Mar 23, 2011 | 2000 Mercury Grand Marquis
My 1996 evo 4 did have over boost got that
r u getting right fuel presure, mine used to keep cutting out after giving it a bit hard throttle ,like it was running on 3 and some times cut right out and the fuel pump when warm was loosing pressure
Aug 13, 2009 | 2004 Mitsubishi Lancer Evolution
PC wont boot up after power cut
probably the power cut shorted one of the components on the computer.
Jan 02, 2009 | HP Compaq ProLiant DL380 G4 Server
Samsung RL36SBMS keeps cutting out, it runs for a few hours the stops and gets warm if i turn it off and on again at the panal at the front it will start working for a while? any ideas?
This is not a full solution, but I'll tell you what I did. Somewhere along the way, something worked.
First, I defrosted for about 48 hours. I turned it on, and the same thing happened, as if it was broken.
I took off the back panel (and also the support for the ice rack) mostly. I got all but the top bit off, so it hinged on the top (I was afraid of breaking the plastic. I checked that there was no ice around. I spun the fan, and wiped the grooves where the air flows (to clean it off a little). I put everything back together. It was tricky making sure the wires on the left did not get caught.
Bizzarrely, having disassembled and reassembled everything, it all started working again as if there was no problem.
Incidentally, the blinking light under the "5" seemed to indicate it was in test mode. I tried to somehow get it out of that by holding down buttons for 8 seconds or so, but that did not seem to work.
If this or something else works for you, please do post, but at least this worked for me, and it is worth a shot before buying a new fridge.
Incidentally, I have read enough to know that I will not buy a Samsung fridge again.
Apr 17, 2008 | Samsung RB1955VQ Bottom Freezer...
Toshiba gigabeat MES60VK (60 GB) stopped working
There is a little battery cut of switch at the bottom of the device. You can unbend a paper clip and switch it off. Then switch it back on after a few seconds. Plug it back into the usb cable to charge it. It should work ok now.
Dec 26, 2007 | Toshiba gigabeat MES60VK Digital Media...
Jan 06, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
