Question about Pioneer Televison & Video
Trying to connect HP Pavilion dv1000 to a pioneer PDP-436XDE, when I connect via 15 pin connection to plasma receiver and laptop, pc channel button pressed on remote, displays window xp start up screen, but than screen goes blank. the cable purchased is HP Monster VGA CAble high performance.
  • 12 Answers
SOURCE: Connecting laptop to LG Plasma via vga cable
you should have a button that you have to press to get it to switch over, on mine i have to press and hold the Fn key then press the F4 key might not be the same on yours but you should have a f something key that has what looks like a little screen on it that is to switch the output if that does not work try hooking up your laptop just like before, and then restart it. good luck
Posted on Sep 30, 2008
localwonder
  • 6784 Answers
SOURCE: where can I sell a pioneer pdp 5070pu plasma tv for parts?
HI, the best way to do this is to disassemble the set and post all the individual internal parts like the power board and main PCB logic and v boards, on line on a e-bay type of sale forum. this way, you can make more money. if you post the entire plasma screen with the crack as is, you will not get many hits. is will be assumed that it is damage goods.
Breaking this set down and, posting the internal circuitry piece by piece will make you more money in this case. The power supply board will sale for at least 289.00. and the main logic(PCB) will sale for 300 to 350. i would go this route to maximizes your gain.
Posted on May 20, 2009
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
tvservice306
  • 458 Answers
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Posted on Nov 18, 2009
  • 4 Answers
SOURCE: Will the Pioneer PDP-R03E Plasma TV Media box work
Yes it will
Posted on Jan 14, 2010
How can I connect a coaxial cable to Pioneer PDP-505CMX 50 in. Plasma Television
If it has a coax fitting on the back connect there. If it does not have (means it is a monitor with no tuner) connect with a/v jacks to the correct input (component?) from a box and select that input to use for watching programs----picture will always be better via rear inputs than coax.
If you have questions press the make a comment button here.
Mar 25, 2012 | Pioneer PDP-505CMX 50 in. Plasma...
How to connect my HP Pavilion dv1000 PC Notebook to led tv please help me
Doesn't you have a manual to do it,it is just a simple problem if we have a picture instruction,you only need to connect with them rightly,and make a correct setting in HP pavilion dv1000.
Feb 17, 2011 | HP Pavilion dv1000 Notebook
My HP Pavilion laptop no longer connects to the internet via wireless.
When wired go to Lan Settings which is under Internet Explorer>Tools>Internet Options.>Connections>Lan Settings. Make sure no boxes are checked after clicking Lan Settings.
Jul 06, 2010 | HP Pavilion dv1000 Notebook
I had to reload my laptop hp dv1000 and have windows xp. having problems with the wireless light not coming on and not being able to connect to the internet
Try this..
Go to Control Panel > open Network Connections >
Setup New Connection manually bcoz,when U reloaded Ur laptop hp dv1000 with Windows XP, all Ur connections Would Have Got Deleted.
Mar 14, 2010 | HP Pavilion dv1000 Notebook
I connected my hp laptop to my pioneer plasma via svga cables. When i select my pc input using my tv remote it says "plasma display no input signal". How do I fix this?
Hello. You have to go into your Display Settings, in your HP Laptop, and chose the Dual Screen/Monitor Setting & make sure you check the "Extend my Windows Desktop onto this Monitor" Box. If you are trying to view your Internet Browser on your TV - you will need to Click on and Drag your Browser to the Right... of off your Laptop Screen and onto your TV Screen. This will take care of your problem!
Jan 11, 2010 | Pioneer PDP-5071HD 50 in. Plasma HDTV
My brandnew Pioneer PDP-5020FD won't turn on.
Check page 9 of this document:
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/PDP-5020FD_OperatingInstructions0610.pdf
You will see that there is a power button on the bottom right corner of the back of the unit (item 25). Turn the unit on using that first.
Mar 17, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Upgrading media receiver on Pioneer PlasmaPDP-5030HD
You can use a PDPR06U if you can find one for sale its 2 generations later than your's. Look on Ebay. I might have one too but I got to look.
Jan 04, 2009 | Pioneer PureVision PDP-5040HD 50 in....
Pioneer 503mxe cant wire it up
To connect as you describe you will need a tuner card as the 503MXE is a monitor rather than a receiver. Otherwise the only option is to connect a scart to the 5xBNC connectors (Input 2) but you will need to be sure that your digi box outputs RGB over scart. If you have the optional video card (PDA 5002) fitted then you can connect via the s-video connection (Input 3) assuming your digi box has an s-video output.
Dec 14, 2008 | Pioneer PureVision PDP-503MXE 50 in....
Media Receiver will not work
took cover off my pioneer MR it's a pro-r05u and will not turn on - any one know the rest procedure for this model. the lights stay on - no blinking.
thanks,
Apr 18, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Televison & Video Logo
46 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
