Question about VillaWare Mickey Mornin' 5555-11 2-Slice Toaster
Mickey mouse villaware 2 slice musical toaster does not play the marching song anymore.....can I fix it??
  • 32 Answers
SOURCE: Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jun 05, 2008
  • 883 Answers
SOURCE: 4 slice toaster
open the unit. look for disconnected wires from sloppy factory
Posted on May 21, 2007
SOURCE: 4-slice egg & muffin toaster
RE: my post from 4/14/08
I called the 800 number and told them of my problem with the egg poacher not working after 7 months of use. To my delight, they have promised to send me a new unit!!
Posted on Apr 15, 2008
  • 32 Answers
SOURCE: Dualit 20247 2-slice crumb tray needed
At the Dualit Service Center:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
SOURCE: T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
Posted on Aug 31, 2009
Need Manual for VillaWare Micky Toaster 5555-07
You will only find a manual on how to use it . If it doesn't work buy a new one ,as it will cost more to get it repaired .
Oct 16, 2014 | VillaWare Kitchen Appliances - Others
Why is my Mickey Mouse Waffle Maker 5555-02 cooking hotter than normal?
The top of your waffle maker has an indicator on the top that shows when the heating coils are on. It should go out when the iron reaches the correct temperature. If it does not go out it may mean that the contacts are stuck and that it is dangerous.
Jul 27, 2014 | VillaWare 5555-01 Mickey Mouse Waffle...
We have the four slice toaster. The arm on the left will no longer stay down. The side still toasts, but the arm will not lock in the down position.
try removing the lower claening plate and remove the bread crumbs and see if that makes it work again. Many people don't know there is a cleaning try on the toaster.
Mar 21, 2010 | VillaWare 5850 Uno Classic 4-Slice Toaster
Villaware mornin toaster 5555-11 When you put the
When you push the slide down on the side, there's a wire that it pushes down inside the toaster. If the wire gets bent down a bit, pushing the slide down doesn't push the wire down enough. The wire is like a teeter totter. When it gets pushed down, it closes the circuit which turns the toaster on. The reason why the slide doesn't stay down is without energy, the electromagnet doesn't get engaged. That's what keeps the slide down. You need to remove the 4 screws on the bottom, and the 2 screws that hold the legs on that also hold the side on with the slide. Once the side is off, take a pair of needle nose pliers and bend the wire up a bit that acts as the teeter totter.
Jan 03, 2010 | VillaWare Mickey Mornin' 5555-11 2-Slice...
Villaware toaster parts
dear cflanagan, my villaware toaster red switches are broken too. did you find replacements if so email me phillyeagl1@yahooo.com
Dec 05, 2009 | VillaWare Mickey's Classic 4 Slice 5555-08...
Expensive toaster doesn't work
I broke mine trying to fix this, but the fix is very easy. remove the out shell and you will see two prongs with contacts that engage when the plunger is pressed. The plunger will not stay down because the prongs are bent and/or dirty. clean the contact, push the prongs closer to the contact and that should do it. Becareful about how you disconnect and reconnect the wires. That is the mistake that I made, and the fuse blew. BTW, if you fix yours, please let me know what kind of fuse is on it. The fuse is in a sheet in a cluster of wires between the two plungers.
Aug 16, 2009 | VillaWare 5850 Uno Classic 4-Slice Toaster
Black & Decker T-1029 2-slice Toaster - lever broken
Main problem with these is crumbs, they get stuck between the 2 surfaces of the small electromagnet that keeps the lever down, consequently it does not stick anymore, try drop kicking it in the drection of the garbage can, this sort fright may just scare it into working again.
Aug 11, 2007 | Black & Decker T1029 Classic Chrome...
VillaWare Mickey Mornin' 5555-11 2-Slice Toaster Logo
324 people viewed this question
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
