Question about Kohler Infinity Bath Bath 5 whirlpool - K-1487-H2-45 - Wild Rose
We have a Kohler Whilpool Infinity Bath, 1983 edition, and the jets just shut-off and stopped working. Any idea what we can do?
What is the best and safest way to remove the bacteria flakes from a Kohler Purist BubbleMassage Air jet tub?
http://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1198327_2.pdf
Call 1-800-4KOHLER 1-800-456-4537)
some parts are under warranty,call them b4 you do anything,they will help figure it out,the link is your manual
May 31, 2015 | Kohler K-1110-G-96 Purist BubbleMassage...
Air blower does not come on after taking a bath to dry jet plumbing. Blower does work if blower button is depressed.
water has to be a certain depth, and the dryer blower I think comes on much later,what do the directions say?
Feb 27, 2010 | Americh Madison II Tub - 7236
Kohler sok overflowing tub motor will not run theres power and green light indicates it should work
maybe the motor is not working any more, if you have curent to the motor but not thru the motor you need to get a motor
Apr 03, 2009 | Kohler K-1188-C1-0 sok overflowing bath...
The water jet pump wont turn off or sometimes turns on by itself
go online to kohler and they will send you out a new switch,, it isn't that hard to install, this will solve your problem and I think if you tell them it was put in not to long ago they will send it for free
Apr 03, 2009 | Kohler Devonshire 5ft Drop-In Bubble...
Heater doesn't work correctly
I think the pump is going out on reset or hi limit
Mar 13, 2009 | Kohler Riverbath Quadrangle Whirlpool w/...
Whirlpool jacuzzi jets not working properly
im not a great expert in this field but try putting some dish washer tablets in water when running to see if they can clean out anything,about 3/4 tabs
Mar 03, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
No water hot
does it have a heater in the circulation line, it should be under the cover and would be in line on the 2 inch pipe that feeds the jets, it should also be on a gfci, check to make sure it is plugged in if this is plugged in and not tripped you need to install a new heater
Dec 06, 2008 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Kohler Infinity Bath Bath 5 whirlpool - K-1487-H2-45 - Wild Rose Logo
Top Kohler Water Heaters Experts
Donni Steen
jdthefixer
Gene Haynes
Are you a Kohler Water Heater Expert? Answer questions, earn points and help others
