Question about Broderbund Mavis Beacon Teaches Microsoft Office Full Version for PC
I have Vista and program will not run. - Broderbund Mavis Beacon Teaches Microsoft Office Full Version for PC
    Guru:
  • 679 Answers
If your Broderbund Mavis Beacon Teaches Microsoft Office is version 16 and 12 you need to upgrade it first to run in Vista with nos issues.
Posted on Dec 30, 2010
Can not get Adobe PhotoDeluxe2.0 to install on windows 7. Worked fine on Vista
Adobe Photo Deluxe is an older program that does not seem to be compatible with Windows 7. you should contact Adobe to see if they have an updated version.
However, you can try the following to see if it will help.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1)Right click on the Program
2)Click on Properties
3)Click on Compatibility tab
4)Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Oct 04, 2013 | Microsoft Windows Vista Ultimate Edition
I have acd-rom that is a windows 95/98, and I want to download it to my vista computer. How?
Win 95/98 programs may not run on Vista.
However, it is possible they might run if you try running the program in "Compatibility" mode.
Here is a link...
http://filext.com/faq/run_old_program_xp.php
Here is another link...
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
You can also search on "Vista compatibility mode" for other sites.
Dec 28, 2011 | HP Computers & Internet
I want driver of shro am-400 for win vista plz do needfull
Well sorrsy to say but there is no win vista driver's for this model, anyway there is a way to use windows xp drivers in windows vista, follow the below steps -
1. Click the "Start" menu in the lower left-hand corner of the Windows Vista screen.
2. Select "Run" from the Start menu.
3. Type "msconfic" in the Run box. Click "OK." A window will appear that lists all of the programs scheduled to run when Windows Vista is turned on. Uncheck all unessential software programs. Be sure to leave critical programs checked, such as antivirus and firewall programs. Click "OK."
4. Click the "Start" menu and select "Restart" to reboot the computer.
5. Open "My Computer" (located in the Start menu or on the Vista desktop).
6. Double-click the "C:\\" drive. Find the installation directory for the Windows XP program or device that you wish to run in Windows Vista. The installation directory is usually given the name of the program, the program's manufacturer, or a shortened version of either of these two options.
7. Right-click the program or driver. Select the "Properties" option in the pop-up menu that appears.
8. Click the "Compatibility" tab in the window that appears. Check the box next to the heading that reads, "Run this program in compatibility mode." In the drop-down menu, select "Windows XP." Click "OK" to close the window. The program or driver will now operate in Windows Vista in Windows XP compatibility mode, allowing the driver to function as it did in Windows XP. Note that the Windows XP driver will not be able to take advantage of any of the new features in Windows Vista while it is running in compatibility mode. You can also follow the below link for more help -
http://www.softwaredriverdownload.com/try_fool_windows_vista_to_install_in_windows_xp_mode
Good Luck!!
Jun 08, 2010 | Sharp AM-400 Digital Multifunction Printer
How to run turboc in full screen in windows vista ultimate
Windows Vista And above doest not support full screen command window.. In order to run dos programs in full screen mode u can you use dosbox emulator which will be more convenient. Note that if you use pointers in your program it may not wok under vista directly.. If u run under the dosbox emulation it will work fine.. You can download dosbox from http://www.softpedia.com/get/Programming/Other-Programming-Files/DOSBox.shtml
Sep 22, 2009 | Microsoft Windows Vista Ultimate Edition
I have installed a windows program on my computor only to find that it will not run on my vista program is there a patch to allows this to happen?
check the program's website for compatibility issues. see the "system requirements", and also check if your windows vista is 32 or 64 bits.
Aug 28, 2009 | Microsoft Windows Vista Ultimate Edition
Why windows vista donot sopport the program of windows xp.
some applications designed for xp are simply not supported by vista.
you can try to find the same program which was designed for vista.
or maybe run a virtual xp on run your program through thaa
May 19, 2009 | Microsoft Windows Vista Home Premium with...
Cannot upgrade windows vista home premium from disc
Check the programs that vista says it can not update. They may be incompatible with Vista. You can find this out by running the Windows Vista upgrade advisor available for free at microsoft.com. If you really want Vista & can do without the offending programs you can uninstall them & then run the upgrade. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | Microsoft Windows Vista Home Premium with...
Philips digital converter 1.0
Go to the manufacturers web site to see if they have a driver for Vista,
but you may also be able to run it in "compatibility mode".
Not all older programs will work under Vista.
Software vendors are working to release Vista-compatible versions everday but in the mean time you can run the program in "Compatibility Mode."To do so:
  1. Open Windows Explorer.
  2. Location the programs folder(My computerC:Program filesPhillips) and find the executable.
  3. Right click the executable and click the Properties option.
  4. Select the Compatibility tab.
  5. Select the Run This Program in Compatibility Mode option.
  6. From the drop-down list, choose the operating system you ran before upgrading to Vista or just go with XP if unknown,you can always change it again..
  7. If necessary, select the option to run the program as an administrator.
  8. Click OK.
  9. Start your program!
[tags]Vista, Windows, Microsoft[/tags]
Jan 01, 2009 | Philips PTV100
Can't install micro. office on vista
there is an option called programs and features ...
and if u want to install a program install it in a normal way
Oct 30, 2008 | Dell Dimension 2400 PC Desktop
I am trying to move my Bookkeeper program to a new Vista Computer. I am getting a message that I am trying to run an older version of Bookkeeper with newer pogram. My old computer is XP and the new one...
Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If an older program doesn't run correctly, use the Program Compatibility Wizard to simulate the behavior of earlier versions of Windows.
• Open the Program Compatibility Wizard by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
NoteTo find out if your programs (or programs you plan to buy) are compatible with Windows Vista, go online to the Windows Vista Compatibility Center. This website contains a comprehensive list of programs, computers, and devices that have been tested to work with Windows Vista.
Oct 24, 2008 | Computers & Internet
Broderbund Mavis Beacon Teaches Microsoft Office Full Version for PC Logo
70 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
