Question about Bosch 24 in. SHE43C05UC Stainless Steel Free-Standing Dishwasher
My Bosch dishwasher won't start. All of the buttons on the panel are dead. I've checked the breaker box & it has power going to it, but it acts as though the breaker has tripped.
  • 13 Answers
SOURCE: Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Posted on Aug 20, 2008
SOURCE: dishwasher is "tripping" the breaker & not draining.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
Posted on Jan 09, 2009
  • 10 Answers
SOURCE: Bosch dishwasher SHE44CO2UC/22 no power or light
Hi sir,
first thing to say is that whether it may be an short circuit between circuits,,or due to an over voltage the fuse may be burnt,,please check the control panel..back of dishwasher,,,
if u checked fuse and circuit,,and think no problem with incoming voltage ,,the control panel's capacitors or resistors may be burnt..
if so please go to a tech,,,,,
thank u,,,for using fixya
Posted on Jun 26, 2009
  • 49 Answers
SOURCE: Our Bosch dishwasher will not turn on. It appears
check the dishwasher electrical box connection. remove kickplate. box is on r/h side. remove cover. you will probably find the wires and marettes burnt. simply repair the wires. this happens from time to time if the connection is not the best. hope that helped
Posted on Aug 20, 2009
SOURCE: Bosch Dishwasher will not power on
I have a bosch dishwasher model 2046. When you try start the cycle you hear the timer inside start to activate but the cycle doesn't start. The light in the start switch does not come on as well but I think it may be burned out. We have checked the breaker and I seems to have power.
Gerald
Posted on Oct 31, 2009
Bosch SHX4605UC/30 dishwasher won't turn on
Since you have power to the dishwasher, check to see if there is a push button reset, there could also be a fuse blown.
Jan 21, 2013 | Dishwashers
I have a shu43 bosch dishwasher and the whole machine is dead. No power. The circuit breaker is good but I would have to pull the dishwaher out to check the outlet. Is there an internal fuse?
There is no internal fuse (at least I've not seen or replaced any) on Bosch dishwashers. The most typical problems for Bosch are: 1) one of the power cord connections to the internal wiring is corroded and doesn't make a contact; or 2) the power button has failed.
The number one is so far the most common problem. To check: Turn off the power to the dishwasher by any means necessary. Remove the kick panel on the bottom. There should be a small metal box with power cord and 2 or 3 wires coming into it. Remove screw(s) holding the cover on that box. There should be 2 or 3 wires connected to the power cord wires by wire nuts. Any burnt insulation or wire nut will be the problem area. Cut burnt wires, remove 1/2" of insulation and clean of both connecting wires to bare copper. If you have an electrical contact grease - apply to copper. Install new wire nut.
Good luck,
Vlad with First Choice Appliance, Sacramento, CA
Jun 28, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher SHE66C06UC is DEAD. Push Power Button and nothing happens? We did have a power outage just before this happened. I cannot find a fuse. Any suggestions?
Welcome to FixYa.
Based on your post it may just be a loose/burnt connection in the dishwasher junction box or a severed wire in the door panel.
** I would start by first shutting off the breaker...safety first**
Then removing the kick plate ( access panel at the bottom )...
...and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance".
Typically this will manifest in just the manner you've described.
If it looks OK there I'd remove the outer door panel ( careful the edges are sharp ) via the six #20 torx head screws...
...check for a severed wire at the pivot point in the door, typically covered in a plastic casing as shown here..
The small plastic blocks which may be present in the bottom corners of the door panel, i.e.
...they can be a pain to re-install, but they do only go in one way, however it is ok to leave them out...their only purpose is to strengthen the structure.
Ultimately it could be the main power switch is cooked, but I'd certainly check what I've suggested first and go forward from there. Good luck.
Let me know what you find and I'll try to assist you further if necessary. Thank you for choosing FixYa today for your inquiry.
Regards,
Macmarkus :)
Feb 06, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Hi! My Bosch began by tripping the breaker during the cycle (several times if I could get it to reset) and now will not start at all. Even when the dishwasher is off I cannot reset the breaker unless I...
Hello
Welcome to Fixya.
Based on your post,"...Even when the dishwasher is off I cannot reset the breaker unless I kind of move the machine around a bit. Sometimes it pops the breaker just closing the door..."
These are the most common reason for these Bosch dishwashers not having power.
#1
I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line.
i.e.
#2
A wire severed inside the door panel, hence the breaker trips by just moving the door in an open/close motion.
Check thoroughly in this location...
The end result is tripping the breaker and no power to the controls.
Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you.
Good luck.
Regards,
Macmarkus :)
Oct 06, 2010 | Bosch SHU9915UC Dishwasher
My bosch dlx series dishwasher acts as if it is getting no power at all. Have tried the circuit breaker. No luck.
Hi Kristen,
Welcome to Fixya.
Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line.
i.e.
The end result is no power to the controls. Check it out and post back what you find.
Good luck.
Regards,
Macmarkus :)
Sep 22, 2010 | Bosch Dishwashers
I have no power to the dishwasher.No lights light up om the control panel.Checked circuit breaker and there is no problem there.Is there a fuse or power reset button.
if you definetely have power into machine its sounds like a pcb fault these can blow out tracking or relays on pcb causing dead machine can be replaced but not cheap.
Aug 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
DISHWASHER COMPLETELY DEAD
Hi John, and welcome to Fixya. I don't believe the greasy water sitting in the machine has anything to do with the problem, rather it is likely a by-product of the problem. Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
May 25, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch dishwasher, model SHE46C, will not start. The circuit breaker is not tripped. Once in a while when the start button is pushed, it does sound like a pump is coming on and then it stop. Any ideas...
Hi D. McKinney and welcome to Fixya. The problem could be a a simple one like a poor connection at the dishwasher junction box. Based on your discription that's what I'd suspect. Having said that I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
May 14, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
I saw my repair man do the following, which you might try...
Open the door and simultaneously press & hold down the power button with the 2 buttons used on your model to "Cancel & Drain." If the unit comes on it now is in self-diagnosis mode. Release the buttons and close the door. The unit should start to fill with water. Press the power button to exit the mode.
Jun 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
My Dishwasher has no power.
have you check at the junction box behind the front bottom panel?? is the breaker ok?/ most newer homes have a switch above the counter to kill the power is that on ?? check that and let me know
Mar 15, 2008 | Bosch 24 in. SHX46A05 Stainless Steel...
Bosch 24 in. SHE43C05UC Stainless Steel Free-Standing Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
