Question about Whirlpool Duet GHW9150P Front Load Washer
I have a code fdl coming up. What does that mean?
    Novelist:
  • 99 Answers
FdL means that the main circuit board (CCU) is not communicating with the door lock and the door needs to be locked b/4 the washer will work. The door lock is rarely the problem. Most often its cold solder joints on the CCU circuit board causing the bad communication. Many times a F11 code comes along with the FdL code. To repair this problem the CCU circuit board needs to be removed and the solder points where the spade connectors and the relays are connected to the circuit board need to be soldered over again. This all stems from poor quality control when the circuit boards had the components soldered to them. The process was able to adhere the smaller connections but not the larger ones compleatly. If your not to handy with a soldering gun you could take this response and show it to a good appliance repair outlet and they should be able to repair your circuit board. Good Luck.
Posted on Dec 31, 2010
USED TO GET F06 CODE AFTER SHORT RUN TRYED NEW MAIN CONTROL PANEL,CONTROL BOX FOR MOTOR, DOOR LATCH NOW ALL I GET IS Fdl
sorry but we do not know the make,model so we can not assist .fdl could mean failed door lock
Oct 27, 2015 | Washing Machines
What is code FDL
FDL code is a door lock code on these washers, but be advised, the older models had an issue with the main control boards loosing connection at the soldered joints for the door switch. They would loose solder, and the board would think the fault was the door lock and it was actually the board.
Nov 11, 2013 | Kenmore Elite 45986 Front Load Washer
F-dl
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates a bad lock assembly. Here is the lock to order.Below is a video to show you how to replace the lock assembly.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
Flash FDL code
Fdl error code means a "door lock error code".
This error shows up because the door cannot be locked. The door will try to lock six times before displaying the error code. In order to solve it, your door lock switch needs to be replaced.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | Washing Machines
The washer will not spin or run.. The code that comes up is FdL?
I think that means front door latch make sure there isnt something in the door track
Feb 15, 2011 | KitchenAid KHWS02R Front Load Washer
When pushing start, washer beeps 3 times but won't start
Is the machine showing a "code" like FdL or F11 in the window where the numbers count down? The machine won't start because it thinks there's a problem. FdL and F11 are often times the codes most displayed when the machine beeps and won't start. FdL means a door lock problem and F11 means a motor or motor control board problem. If it's flashing either one of those codes the problem is most often the CCU circuit board in the machine (inside, top, back, plastic case) The CCU circuit board has what's called cold solder joints causing bad communication between the CCU and the door lock and/or the motor or motor control board. The cure for this is to remove the case with the circuit board then remove the circuit board and resolder the points on the circuit board where the spade connectors and relays (5 of them) connect to the circuit board. If you're good with soldering techniques the job is easy. If not, take the board in the case to a good appliance repair shop (along with this response) and they should be able to help you out. Good luck.
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We keep getting a dl f code and the washer will not finish the cycle.
The FdL code means a communication error from the door lock to the CCU (one of the circuit boards that run the machine) Unfortunatly the fix isn't easy. The problem is the CCU. Whirlpool had some bad quality control when these circuit boards were made and there are cold solder joints on the circuit board where the relays and spade connectors are connected to the circuit board. You'll need to remove the circuit board and touch-up those connections or have a good appliance repair shop do it for you. The circuit board is located in the machine at the top, back, in a plastic case made out of some cheap plastic. Mark all the connections or take a picture of them before you remove them, they are keyed but it still helps to mark them. Just take out the whole plastic case, it's easier. You will break some tabs getting to the circuit board (remember, cheap plastic) Once you have those connections touched-up it will also take care of the F11 code that often times comes with the FdL code. Good luck.
Dec 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does code FDL mean? kenmore elite wash maching
You are getting and error code F-DL which means the main control board is sensing that the door is not locking. Most likely a problem with the door lock/latch assembly.
Feb 02, 2010 | Kenmore 45981 Washer
Whirlppool front loading washer won't start, code FdL, door can be opened
"Fdl" is a door latch FAILURE error code. What the error is telling you is that something is malfunctioning with the electronic door latch and/or interconnecting wire or Central Control Unit. It is recommended that you check the wiring harness connected to the door latch or, replace the door latch. The following link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you have any questions or concerns please post back and let me know. I hope this helps you.
Aug 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fdl Code on whirlpool front load washer
remove bottom panel reach up to bottom of door lock there is a small tab pull it down door will come open..if after opening you finda lot of water still in machine suspect pump plugged worse case bad control bd
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
439 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
