The hard drive will power on, but won't register on the computer. it makes a slight clicking sound towards the back of the device.
    Scholar:
  • 73 Answers
If the system BIOS won't register or recognize your hard drive it means that you've got a bad hard drive. other things that you can try is to use other SATA cable. By the way, if the motherboard able to detect other SATA device such as DVD drive. it means that your motherboard is okay.
Posted on Dec 30, 2010
    Guru:
  • 2,178 Answers
Your hard drive is damaged.
External hard drive won't boot up.
As virtualhost said, maybe you have not initialize this disk and partition it. Additional to disk mgmt, you could use this software
Sep 11, 2012 | Buffalo Technology (USA), INC. - 500GB...
Verbatim 1 tb frozen
the screeching noise worries me a bit
its sounds the video file being transfered was a bit to much for the usb capacity
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
even if you dont have any red or yellow marks you might have to
Click Start, then type device manager in the Search box then click Device Manager
Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
Once complete restart your computer. Your USB controllers will automatically install
This method prevents your USB external drive from powering down
Disable USB selective suspend setting.
This method prevents your USB external drive from powering down.
Click the Start button type power plan in the Search box then click Choose a power plan.
Next to your currently selected plan click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings then expand USB selective suspend settings.
Click Plugged in then click the drop down menu and select disabled.
If youre using a laptop click Battery then click the drop down menu and select disabled.
Click Apply then click OK.
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
you might have to install a usb 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jun 28, 2012 | Computers & Internet
My WD element extrenal hard drive won't open. i can see it in my devices, and the blue light stays on. it also makes the sound saying it's connected but I can't see the device in my comput
First thing, try to change the cable, try a different one, then if it does not work, try to connect the hard drive on another computer, and changing cables as well. This will help you to narrow down the problem to find out exactly what the matter is. If the Hard drive spins properly and it does not produce any click-click sound then it is fine. If all the above fail, then you have to slave the hard drive using its internal SATA connection. You have to open up the hard drive and remove the pin that connects the hard drive to the cable. This will enable you to see the SATA connection. Slave the Hard drive on a desktop computer and see if you can gain access to it. If you can, then consider replacing both the cable and the pin that connects the cable to the hard drive. If your hard drive just spins and you can not access it while its a slave to another computer, then the hard drive has a problem.... Try the methods above, i believe your hard drive did not go this bad...
Mar 26, 2012 | Western Digital Elements powered by WD 320...
Rikiki external hard drive clicking sound
The clicking noise is an indication of a head-crash. The drive is damaged and won't be usable. Restore your files from your backup drive.
If you don't have a backup drive, you'll have to pay someone to try to recover your data.
Feb 12, 2012 | Computers & Internet
HI ON My LaCie External Hard Drive, the power LED continuously blinks and won't mount. It was working fine one minute and the next minute it was down.
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the usb. If you have received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 07, 2011 | Computers & Internet
My portable hard drive wont connect to my computer. When I plug it in a blue light on the device light up, and it makes a constant beeping sound, but my computer does not register the device. It works on...
hi there,
While the Hard drive is connected to one of the USB ports on your computer.
On your keyboard press and hold the power button and press the letter R.
When the Run box comes up type in devmgmt.msc
Expand the Universal Serial Bus cotnrollers
right click on every root hub and choose uninstall
after that restart the computer
Hope this helps!
May 05, 2011 | Verbatim 96823 320 GB USB Portable (Blue)...
Plug in cord and just hear clicking noise not connecting to a computer
This means that the WD could is trying to connect to the computer but looses the connection. Try plugging the usb cord in another usb slot on your computer. Or try using another cable. Make sure the WD is not giving out any red led light on the device.
Mar 01, 2011 | Western Digital My Passport Essential...
My 80-GB HDD is making a clicking sound then
Connect the Hard Drive and restart the Computer. If it's not detected then open the Device Manager, click on the View menu and select "Show hidden devices".
Next, click on the plus sign next to the "Disk drives" and uninstall all the devices that you know are not present. Uninstall all the devices listed under the "Storage Volumes" and the "Universal serial bus controllers". Avoid all the reboot prompt until you're done uninstalling all the devices. Also make sure that the Device Manager doesn't have any exclamation mark beside any devices.
After uninstalling all the devices, restart the Computer with the Hard Drive connected.
Sep 09, 2009 | Iomega Computers & Internet
Dead drive?
Ok! This is bad, just like any HD when you start hearing noises clicking, vibrations, it is due to a loose or faulty cylinder. These things are not worth the repair and your files are lost. The only thing that you can do is try to hook this up to another PC to see if it will work long enought to extract the files. Keep in mind a lot of companies manufacture these devices, but there largest business is geared towards Microsoft customers, so if you have a Mac do not count on guarantees for these devices to function properly with your unit.
Nov 24, 2007 | LaCie (300770) 250 GB Hard Drive
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
