Question about GE Profile PDW8400J Built-in Dishwasher
I have had this dishwasher for less than 4 years and the dishes as of about 2 yrs ago stopped getting cleaned. I have a water softner, use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
  • 1,543 Answers
Clean out the holes on the spray arms, or replace the spray arms.
Posted on Dec 30, 2010
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
The clean light on my kitchen aid dish washer kept blinking and would not stop. after reseting it by pushing the buttons 2-3 times it cycles though and stops. then nothing works when i push the...
The electronic control looks for a temp. rise of 2-4 degrees. If no temp.rise control assumes a heater fault and blinks clean light 7 times. Bad heater. Water fill when completed can be no less than 1/2 inch below heater. If so, water valve probably. Circulation motor not working properly. Neutral door switch. Tech sheet is behind bottom cover. Check underneath of unit for leaking or white hard water deposits. Common for seals to leak. If unit is unusually noisy, motor problem. Common after 4-5 years. Will check back to see if you other questions. Good luck.
Mar 28, 2011 | Dishwashers
Dish washer 3 1/2 yrs old making a growling/vibrating sound.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jan 28, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
My Maytag Quietseries 300 has suddenly stopped draining H2O
My Maytag Quietseries has the same problem after less than 2 years. Mine is caused by using granular dishwasher detergent, which is the most common type of detergent. I took apart the entire pump inlet section (need a torx scew driver and a small socket for the impeller) and found the white abrasive material from the detergent (Cascade in my case) was packing in and pluging up all areas of the inlet. After I cleaned it all out & reassembled, dishwasher was back to 100%. Also noticed the normal cycle worked much better as well.
Jul 22, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher does not clean dishes and leaves spots on everything!!
You need 2 things. Slightly hotter water and a rinse agent. If you don't heat dry your dishes, crack the door 3 or 4 inches after it's done, to let the steam out.
Mar 04, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Not cleaning
check the wash arms make sure that they can spin ... open in mid cycle check water level and arm spin...also check water temp... hope it helps
Jun 16, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Samsung DM5710DT dishwasher
the problem is hard water i bet. there is a new product out that actually filters the water going into your dishwasher. this i think is awesome becasue who knows whats in the water cleaning the dishes you eat and drink with. my dishes use to be white and spotty and after the first load with the filter they came out spotless. you can get it at www.dishwasherfilter.com. you will be glad you did. oh it goes under the sink and is small and affordable.
May 25, 2008 | Samsung 24 in. DB5710DT Stainless Steel...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
New dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Sep 06, 2006 | Kenmore 13869 / 13864 / 13862 Dishwasher
GE Profile PDW8400J Built-in Dishwasher Logo
147 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
