Question about Garden
How to adjust the tention on the roller catch
  • 3 Answers
  • Locate the guide bar retaining nuts on the side of the motor that holds the bar. Use the guide bar retaining nut wrench to loosen the two bolts mounting the bar to the motor.
  • 2
    Locate the chain tensioning screw on the front of the motor housing near the guide bar. Turn the screw clockwise to increase tension and counterclockwise to release tension. Tighten the chain until the chain moves freely along the length of the guide bar, but is tight on the curves of the bar
  • Read more: How to Adjust a Chainsaw Tension ' eHow.com http://www.ehow.com/how_4894871_adjust-chainsaw-tension.html#ixzz19dQwO8tJ
    Posted on Dec 30, 2010
    I install new timing chain guides and checked the stretch on the cheain but i can't remove the slack
    Do yourself a favor,and ditch the auto tensioner for a manual type that you adjust yourself. Youll thank me later!...LOL.
    Sep 23, 2012 | kawasaki KLR 250 Motorcycles
    Adjusting chain tension
    There are a number of different types of adjusters, front manual adjusters, side manual adjusters and tooless adjusters, the two latter systems require you to slacken the bar nut/nuts and with a flat blade screw driver turn the screw clockwise to increase chain tention, the chain should touch the bar rails all around the bar with no sagging on the under side of the bar, with a gloved hand you should be able to pull the chain around easily to make sure its not too tight, with the tooless adjuster slacken off the bar nut/nuts and turn the thumb wheel down to increase the tention.
    Jun 12, 2012 | Garden
    Model vx710 upper tread keeps breaking adjusted both tentions
    If the timing is a bit off this could also be causing the thread to break. lf you've had a good attempt at getting the two tensions right and not having any joy, then it could be timing is just out a little.
    I'm assuming that its good quality thread and same top and bottom and that you've checked the thread paths for any places where it could be catching/jamming etc already.
    If machine has been at least 2 years since a service then might be time to take it for one.
    Apr 27, 2011 | Brother Sewing Machines
    I need to replace a cracked deck and worn belt. I need the instructions on how to do these things.
    1st take side rails off front hood .you have afront roller and a back roller. for the front take out the two or one bolts holding the the roller in placenow the back roller take out the bolts that hold the roller in place . now on the deck there is 3or 4 screwson each side holding the deck in place. slide w/ belt off put on new deck.install screws, rollers ,bolts.. now center w/belt and adjust tention on w/belt
    Feb 28, 2011 | Cardiozone Supersport Hr Club Commercial...
    How to adjust a tensioner on a 2001 chrysler voyager
    You mean your belt tentioner, serpentine belt, it is not adjustable if your belt is coming off you have a bad tentioner, bad pulley or your power stering pump is leaken and your belt is soaked, if oilly firts found your leak (most common is a hose from reservoir to pump) then replace belt with a cheap belt (had lost of trouble with Life time or hi dollar belts), in the mean time also inspect your tentioner if ani play side ways replace it, also remove idle pulley and spun it close to your ear, if any noise replace it, you may get away with a single item changed, but for trouble free time, replace all items: belt tentioner ($38) idle pulley($25) serpentine belt ($25)
    Oct 17, 2010 | 2001 Chrysler Voyager
    Men Mountain Bike (26"): How to adjust tention on the rear brakes...
    Your bike likely has linear pull brakes so you will need to a. loosen the pinch bolt that holds the brake cable to the noodle (down at the wheel). You then pinch the brake in towards the rim with your hand until it's almost touching and then retighten the cable. You can then do some fine adjustment on how close the brake pads are the rim with the adjusting nuts up at the levers.
    May 18, 2010 | Huffy Men Mountain Bike (26")
    Crescent-shaped burns on clothes from dryer
    Hello Friend, Your problem is very simple to fix. You need to replace the Rear drum support rollers. To replace the Rear drum support rollers just remove front of dryer body exposing the drum, look under the drum and you will see the belt and tention wheel in front of the motor. Now, release the tention on the belt and remove belt from motor shaft. At this point you can remove the drum up and out of the dryer cabinet. Look towards the rear of the dryer cabinet and you will see the rear drum rollers. The roller on the left has a support strap held on by a press on clip. just pry this clip off and remove support bar. Now there will be a plactic triangular clip holding the roller in place. Just remove the plastic clip and replace roller. The roller on the right just has the triangle plastic clip just remove and replace that roller as well. Be sure to lubricate the roller shafts with some 3 in one oil prior to re-installing the new rollers. Make sure you re-install all of the retaining clips. After re-assymbly of your dryer if should run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks.
    Dec 29, 2009 | Kenmore 63942 Dryer
    Griding noise while spinning. the unit heats and spins but makes grinding noise as if the drum were off track
    Jun 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
    Garden Logo
    244 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
