Question about Yamaha RX-V463 Receiver
I have hooked up my dish, yamaha receiver, CD player, blueray player and have surround sound for everything but the TV, Help!
  • 312 Answers
Usually, unless the TV show is being broadcast itself in surround sound, the surround decoder in the receiver will default to front only sound on TV shows. When a TV show says that it is in surround sound, the receiver will decode it. I think the Law and Order series in broadcast in surround.
Hope this helps,
Best, Mark
Posted on Dec 30, 2010
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
Insignia nslcd2609
I'm not sure what you mean by "run surround sound from this tv" . If you are using an antenna for HIDEF you would run an optical cable from the tv to the optical input on your receiver labeled CD. If you are using a cable box or using a blu ray player simply run a coax cable from said box or player (digital out) into your receiver labeled DVD and run the HDMI cable straight into the back of your tv strictly for video. Note that some recent budget players have omitted digital audio outputs entirely. Hopefully your player has them. Hope this helps. Feel free to ask for clarifications.
Jan 19, 2014 | Insignia Audio Players & Recorders
Yamaha RX-V471 3D video for blu ray will not display on TV
Your Yamaha is the problem here. It cannot handle the signal and process the 3D as it states. What I would do is hook your player direct to your TV in the manner that it works and feed your audio from a different path to maintain surround system. Your tv/dvd player may have an audio out that you can feed back to the Yamaha .
Jan 11, 2014 | Yamaha Rx-v471 3D A/v Receiver
Find Blu-ray player compatible with Yamaha htr-5830
Hello James,I have the exact same issue, did you have any luck?
Dec 28, 2012 | Yamaha HTR-5830 Receiver
I HAVE A 50" PANASONIC PLASMA TV THAT I WOULD LIKE TO HOOK TO DISHNETWORK AND A SONY SURROUND SYSTEM AND A BLUERAY PLAYER. dOES ANYONE HAVE A DIAGRAM OR CAN EXPLAIN HOW TO DO THIS?
The owner manual will have diagrams for this and images, also Dish may come out and set things up correctly and may or may not charge for that--get it done the first time right.
Dec 17, 2012 | Panasonic Televison & Video
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Having trouble connecting my blue ray and tv to my yamaha receive and surround system
Must be an HDMI ?
If yes use the HDMI DVD input on your receiver ( from the Blue Ray using a HDMI cable )
Then use an HDMI cable from receiver to TV.
That should work for image. Sound would only work directly from TV, to have sound on receiver:
Use either optical or coax cable to direct digital sound from blueray to receiver.
Best is optic, depends on blueray or cable availability ... Coax = RCA cables @ 75 Ohms, use of a spare RGB would work find (using only one of three color available let's say using Red only) or try with any RCA cable.
direct cable from blueray to receiver ( Digital inputs at far left looking back of receiver num 7 in owner manual, choose DVD )
If no sound from receiver check Audio select from option menu ( set to auto )
Any specific question about this procedure ?
or guess you already found out,
Enjoy :-)
Dec 17, 2008 | Yamaha RX-V363 Receiver
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Hooking up the RT 2600
connect all the devices into the receiver inputs then there should be 1 set of outputs to the tv. This is to play everything using surround sound as all the video and audio is going through your recevier... if you want to do HD and have surround sound you will need a new receiver as this one has no hdmi inputs or outputs.
Feb 26, 2008 | RCA RT2350 System
Yamaha RX-V463 Receiver Logo
147 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
