Question about Garden
Need to install auger belt on an Montgomery Ward Snow Blower Mod # GIL35211B
5 Suggested Answers
SOURCE: on my two stage snow blower--main auger stops turning .
Hi, I figured out the problem. The gear transfer case between the augers must be broke. The auger spins slowly until it hits snow and then stops-- The discharge fan continues to spin fast. I will try to get a local handyman to fix it or else but a new machine, this one must be at least 15-16 years old.
I thank you for your help, it is a great service. ojohn
Posted on Dec 12, 2008
  • 138 Answers
SOURCE: have a power kraft 18.5hp with 46'' deck, need a
first you'll need a model number. look on the underside of the seat, or on the metal plate between the rear wheels for the model no. sticker. wards tractors were made by MTD. there will be two numbers plus the serial number, write 'em both down. then log on to www.milacalawn.com. in most cases, you'll be able to pull up an owner's manual for your tractor with one or the other model numbers
Posted on Aug 30, 2009
SOURCE: I have an older snow blower - Montgomery Ward -
Check with Pete. He has great knowledge of these older machines.
http://home.gwi.net/~spectrum/snowblower.html
Posted on Dec 14, 2009
ToolBoxHero
  • 171 Answers
SOURCE: changing auger belt on snow blower
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
I am going to assume you have a Craftsman snow blower. If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drive the auger/blower and the belt closest to the engine drive the transmission.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Your Craftsman manual will show you step by step how to change th belt.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Posted on Jan 13, 2011
Can I get a new rubber track for an older model (not home to get exact numbers ir model) Montgomery Ward snow blower?
OUCH since monkey wards went out of business you need to see what company made it for them .it might have been mtd there were several brands with same type of drive system .
Feb 02, 2015 | Garden
Toro powerlite 98 cc 16" Mod no 38182 ser
Yes, you have a shear pin and that is probably the problem...
The shear pin often will not fall out and look like a normal piece but in fact be broken...
The shear pin usually is in the main shaft from the transmission to the auger drive...
Some are right on the auger its self...look around you will find it...
heatman101
Feb 26, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Montgomery Ward snowblower, single speed how can I slow it down, moves to fast and pluggs up.
well... that's a difficult task, you need to open it up and replace the current gear with a bigger on, if it's possible, it may not be... you could try coating the auger with wax/cooking spray
Feb 13, 2010 | Montgomery Ward (223600UP) Heater
How do you change belt in gilson snow blower?
a. remove belt guard
b. remove springs from idle wheels
c. remove belts from idle wheels
d. remove from drive pulleys
e. loosen belt finger (at bottom edge of top opening)
f. tip up
g. remove bottom cover
h. take belt off pulleys
i. slip belt between pulley and disk
j. reverse process to install
this is assuming it uses a friction disk
Feb 10, 2010 | Montgomery Ward (223600UP) Heater
I have a Montgomery Ward Snow Thrower Model 495A. A rope got caught in the auger. Now the motor runs but the auger will not turn. Any idea what was broken and where I can get parts to fix it?
I have an older Montgomery Ward Snow Thrower model No. TM0-35286A and I'm having a hard time finding parts for it. The tiller just stopped working so I'm thinking the worm-gear is shot, but I can't even find the part on-line...Can you help?
Dec 10, 2009 | Montgomery Ward (223600UP) Heater
I need to know the correct size for the auger belt Montgomery ward TMO 35275B 1274B
I'm not sure which belt is which, but one belt is 3/8" x 29.0" long and the other one is 3/8" x 38" long
Nov 03, 2009 | Montgomery Ward (223600UP) Heater
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
