Question about Century Portable Plasma Cutter 82021
Century 80 wire is hot all the time with out pulling the triger
  • 29 Answers
You have a ground problem
Posted on Jan 02, 2011
I have an 80 amp century welder it arkc without touching the triger
sounds like a relay is stuck closed. locate it and tap with a screwdriver handle.
Oct 14, 2010 | Century Welding Tools
Difficulty changing the wire
check the tension on your drive rolls. Also check if the drive rolls are correct for that wire size.
Jun 27, 2010 | Century 80GS Flux - Cored Wire Feed Welder
My wire dont feed out some time when i pull the triger
Inside your machine just in front of the wire spool is an adjustment to increase the tension on the wire tighten it a little bit at a time until your wire feeds
Feb 05, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
How do i remove the bolt from the mossburg 308 win. and is there a product you offer to modify the triger
if i were you i would leave the bolt alown,,its a hell of a job getting them back in,,,as for the triger i know there a bit on the heavy side to pull at nearly 4 lbs but its a safe pull,you could drop the gun into a gum smith and get him to snip off a coil off the triger pull spring,,and stone the sear,, but be warned it will make the triger twitchy,,you realy dont wont to light a triger on a hunting rifle 4 - 6 lbs is normal
Nov 18, 2009 | Optics
Need an operating manual for the century 80
Do a web search for lincolnelectric.com and look for the manual for this model.
Oct 12, 2009 | Lincoln Electric LE 83180 Century...
1997 VW Cabrio When ignition is turned to start nothing happens. Selinoid and starter are fine. No elec to triger wire to selinoid. I pulled conector from back of switch and jumped from hot to start and...
if you have power to the solenoid on the starter pull in post but nothing happens thenthe brushes need to be replaced in the starter.the brushes let the solenoid go to grounrnd for the lenght of of time it takes to engage the solenoid pull coil and the switch and relay take over during the hold mode of the starter.usually will find the lead from the solenoid to the brushes has rotted off,or brushes are gone.
Aug 20, 2009 | Volkswagen Cabrio Cars & Trucks
Welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
Jan 18, 2009 | Welding Tools
Century Portable Plasma Cutter 82021 Logo
118 people viewed this question
Top Century Welding Tools Experts
John Trevino
Ted Maxwell
Tom Chichester
Are you a Century Welding Tool Expert? Answer questions, earn points and help others
