Question about Maxent Televison & Video
My tv try to turn on and i heard i double click and the tv doesn't turn on. The screen is black and doesn't do anything else. my model is pdp42v1
  • luis ibarra Dec 30, 2010
    how much you think it going to cost me a new power supply
    one of the HDMI outlets in my tv doesn't give me any sound i get the picture but not any sound.
  • Maxent Master
  • 17,129 Answers
It is quite important that you need to open the set for a proper diagnosis. As you switch the TV on the power supply section seems to boots up- the SMPS Unit. Now the processor seems to works as it decides to shut OFF due to a failure of the feedback voltage . This confirms that the output sections have a faulty drive which can also be a short in the output drivers. If so you might have to trace up the +B voltages from the main power to the outputs.
A possible short can be easily determined with a continuity test, make sure that the power plug is taken off and the capacitors are discharged before you attempt to test these circuits.-- not to damage your multimeter.
Disconnect the line feeder to the suspected shorted component to confirm.
Make sure there are no dry soldering joints on the PCB, loose connector joints can also cause these symptoms of shunting .
Posted on Dec 31, 2010
    Genius:
  • 1,126 Answers
It is a power supply problem, you can get anew power supply or you can replace the electrolytic caps on the one in the set, that will fix your problem.
Posted on Dec 30, 2010
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
I have a RCA 14"
Main control board is toast. Really not worth repairing unless it's in a specialty location. If it is, it's going to have to go to a repair center.
Jun 25, 2011 | Televison & Video
Watching and Suddenly turned black, but sound still worked.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It seems there is a loose connection between the board producing the picture and the screen; this is why this would happen. If turning the TV on and off makes no difference, try contact Phillips to see if they can talk you through a factory reset. If this does not work, the set may require service.
Jul 16, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
TV turns on, No pictura at all, and a clicking like a signal light can be heard.
sounds like you have bad convergance amp ic.
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 20, 2007 | Hitachi 46F500 46" Rear Projection...
Monitor goes black and both blue lamp blinks
have a tech check your tv there is a fault in tv horizontal circuit.good luck my friend.
Jun 15, 2007 | JVC PD-42V475 42 in. HD-Ready Plasma...
Televison & Video Logo
60 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
