Question about Eclipse AVN5435 Car DVD Player
I dont have the start up disc. It says check map, and yes I recently removed my battery
  • 376 Answers
Well first is all software needed is obtainable from the manufacturer, if you bought it new.
secondly the battery does not always reset the device. what you have to do is disconnect all power sources, and leave it alone foe a few. you did not give me much to go off of, so this is the best I can do whith what you gave me, sorry good luck
Posted on Dec 30, 2010
Do you have to put a special disc to program the sterio
Posted on Apr 08, 2012
  • nune jr Apr 08, 2012
    How can i get the disc
2008 Yukon Denali map dvd doesn't work. It keeps saying "DISC INSTALLED IN NOT A MAP DISC". How come?
All you have to do to remove the disc and press the MENU button on the right side of the touch screen and choose the NAV option to change the search area/database. One of the choices is to eject the disc. Good Luck.
Dec 08, 2014 | 2008 GMC Yukon Denali
94 camry died and won't start we have spark, fuel and compression and a code 31, changed the map sensor still no start
Yes I do believe that fuel is there. Are the injectors working, some time you have all but no fuel. While cranking check if power is there for injector socket.remove the air cleaner pipe the to the inlet manifold spray 2,3 puf of aero start and see if she run for few second. Take care as you spray, first spray and then start the car
If yes you can figure it out the problem
Let us know how it goes. i hope this is some help to you
AD
Jun 12, 2014 | 1994 Toyota Camry
Changed the Alternator and now screen only displays check map disc.. Dont have the disc. What do we do??
you forgot to read the FSM
and step one was:
1:remove battery cable minus lug,
now you blew out that huge fuse in the main fuse box.
oops...a - daisy. the fuse saved you a bath in ACID. (or worse)_
Aug 21, 2013 | Jeep Compass Cars & Trucks
Upgraded Route 66 software on Hema Navigator 5 now has lost the maps. Can they be loaded from the supplied disc that came with the unit?
Yes that is the normal way... install ANY drivers and/or any software that came with the unit. REBOOT. THEN & ONLY then plug in your GPS & Turn ON. The GPS should be detected and Windows will install it. Now you should be able to run the software and upload maps etc. You may have to Reset the Unit. OR try removing the batteries & reseting that will return it to the way it was when you first got it.
Feb 10, 2010 | GPS
I have a 2005 GMC Canyon that the battery was changed about a month in a half ago. Now, If I don't start the truck for a couple of days I have to get a jump start. What is my problem? I think the battery...
Something must be staying on or somehow draining the battery with the car off. Check to make sure lights aren't staying on, check the map lights, dome light, visor lights etc. Did you recently install any aftermarket electronic parts?
Nov 29, 2009 | 2005 GMC Canyon
Maps on SD card not recognized by Garmin C330 GPS
I dont thinki the 330 handles 4Gb SD cards I think 2Gb is the maximum that is why it isd taking so long and runds out of space so cannot properly load the maps.
Jul 22, 2009 | Garmin StreetPilot C330 GPS Receiver
My 1999 dodge intrepid is hesitating to start but wont start
The MAP sensor. Do you have a check engine light on?
Apr 26, 2009 | 1999 Dodge Intrepid
Garmin Zumo 450 will not turn on
try removing the battery withthe included allen key, press the power button to drain all the power inside the system and reinstall the battery and then try it.
Jan 11, 2009 | Garmin zumo 450 GPS Receiver
To make un full reset
Hello Rahooty,
There is no way to set the date and time becayse the system clock in your Garmin Rhino 120 should be updating based on the information it receives from the GPS satellites. The radio should auto locate itself within about five minutes of being turned on providing it has a clear view of the sky. Once it sucessfully auto locates the radio's clock and position should reset. There does not appear to be any other reset built into the device.
Try taking the batteries out for at least 5 minutes. Then, reinstall the batteries, turn the unit on, and give the unit 5-10 minutes to auto locate. If it doesn't, you may need to contact Garmin support for additional sevice.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 05, 2008 | Garmin Rino 120 2-Way Radio
Eclipse AVN5435 Car DVD Player Logo
566 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
