Hello i have a vizio 42" lcd tv... i have read on here and it seams you had the same problem i was just curious if you got urs fixed. i have 5vdc coming out of my board as well but no 12vdc or 24vdc. did you find the fix? any help would be appreciated
  • mhgfuf21 Jan 01, 2011
    sorry i left out model # here it is: VO42L FHDTV10A
  • 11,361 Answers
The 5vdc standby is workingbut the 12 and 24vdc power supply are noty running, it can be due to not getting the turn on command from the main board, or the fault is in the power supply itself, or it sensing shorted circuits in the backlights inverter board so it will not come on.
So look for PSON signal (3.3~5vdc = ON), or disconnec the cable to the backlights inverter board to see if the 12/24vdc will come back on.
You did not provide the model number so I cannot look up the power supply information.
Please read my guide again;
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 30, 2010
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
LCD tv Vizio 42 inch has vertical colored lines completely across (vertically) the entire screen. Here's the picture: [IMG]http://i22.photobucket.com/albums/b320/Relicario/lcdtvverticallines.jpg[/IMG]...
hello imvega7, as i know, 42 inch is a plasma display TV.
Refer to your image, and my experience that symptomp because of connection between buffer PCB and panel. Some cases, dirty conection may cause this symptomp.
Un plug power cord, open rear cover, fine pcb on upper or lower panel.
unplug flat cables from pcb buffer, clean soket using a brush. And also clean flat cables using celaner or alcohol.
Wait untill that conection dry. reassembly and try it.
i hope that help you.
Mar 15, 2011 | Vizio GV42L 42 in. LCD Television
I HAVE A VIZIO LCD TV AND WHEN WATCHING ANYTHING THROUGH THE hdmi INPUTS LIKE BLUERAYS THE SOUND GOES STATICY AFTER 30 MINS. AND TO RESET IT I CHANGE THE IMPUT CHANGES THEN BACK AND THEN ITS FIXED. WHAT...
This problem happen to all the HDMI inputs?Only one HDMI input,that one properally is shorted.Might even the HDMI cable is old,and worn out.U have about 6 HDMI inputs on ur tv,rent about 3 DVDs movies and watches test out all ur HDMI ports out.
Mar 25, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Have a 42 inch vizio lcd has two black lines halfway down the screen that after awhile disappear then reappear had three lines one is gone completely ,curious approx cost to fix is it an easy fix or junk ?
HI I HAD THIS ON MY SONY YOU WILL FIND IT IS AN ELECTRICAL APPLIANCE CLOSE TO TELLY IE WII AIRFRESHENERIN 13AMP SOCKET BROADBAND TRANSMITTER SWITCH ALL OFF AND WAIT ADAY CHEERS
Oct 25, 2009 | Vizio GV42L 42 in. LCD Television
Missing plastic base from Vizio 22" LCD TV
Go to ur tv website buy ur part,Type in ur S/N and part.
Sep 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Flickering white line across top of vizio 47" tv screen
I had that problem on my Vizio 37" and my new Vizio 55" and now after reading the solution of adjusting the HV position in the setup menu, the problem is fixed! Thank you!!
Jun 30, 2009 | Vizio 42 in. LCD TV
No pic no sound
your TV was overheat. check secondary power supply inside chasis. check all the components specially thus budged capacitos.
Jun 03, 2009 | Vizio GV42L 42 in. LCD Television
42 Vizio LCD Tv-
Replace the power supply will fix the problem. Is the Vizio LED light on?
Jan 19, 2009 | Vizio GV42L 42 in. LCD Television
Plasma Vizio 42 inch
The main board of your TV is bad. I have seen a lot of TVs have the same problem.
May 31, 2008 | Vizio 42 in. LCD TV
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
