Question about Canon Office Equipment & Supplies
Canon Pixma MP 780 - Ink cartridge carrier never used to 'move' by hand - it always only moved into position when the top and front doors were opened. Bought a new printer head - turned the machine on to install printer head but the machine cartridge carrier didn't 'move' when the door and top were opened the machine made a banging noise. Message for the problem is "check printer press ok" upon checking the machine I don't see anything wrong except the free moving cartridge carrier - I press ok but the problem doesn't go away. Looked at the back of the machine, but I don't know what to do or how to fix it.
SOURCE: replacing NON Manufactored ink cartridges in EPSON PHOTOS STYLUS R380
hi im jules_09,apparently it will not work because every copier orprinter has its own designated ink cartridges.or even the ink will not work on it too.it goes to all copiers and printers that do not use a imitation of toner or ink or youll have problem with the machine if you want it to work just transfer the new ink into the old cartridge,re use only the cartridge but remember that compatile ink and toner can ruin the operation or even cause big problem to the machine
Posted on Nov 11, 2007
SOURCE: I moved the copier and have a problem with an imagerunner 5000 S
Have you solved this problem yet? Do you have the copier in N.J.????? If not call me 973-900-2209, I may be able to help you, I'm in N.J.
Posted on Sep 12, 2008
SOURCE: print head on Canon Pixma 780 doesn't move
display printer says chec printer ##357
Posted on Jan 15, 2009
  • 990 Answers
SOURCE: Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
Posted on Mar 22, 2009
  • 634 Answers
SOURCE: Canon Pixma iP 6210D: cannot replace cartridges
the drive control is malfunctioning and costs more to repair than replace
Posted on Jul 07, 2009
How do i change the ink
First make sure that the printer is on and the document cover of the scanner is closed. Then lift up the entire scanner unit and secure the support (on the right side of the unit). The cartridge carrier should move to where you can reach the cartridges. Wait until this comes to a stop.
Pinch the tabs on the cartridge cover for the cartridge that you want to replace together. (One is at the front of the cover (near you); the other is on the top of the cover part way into the printer.) Then lift up the cover. Pull the old cartridge out. Open your new cartridge and remove the protective tape. (Do not touch the electrical contacts or the print nozzles.)
Push the new cartridge into its slot (just push forward and slightly down. Make sure that the black cartridge is in the right hand slot. Then close the ink cartridge cover and make sure that it clicks into place. The front edge of the cover should end up parallel to the front of the printer.
Repeat this for the other cartridge if needed. Then lift up the scanner unit slightly to release the support and then lower the scanner unit to close the printer. Wait until the printer stops the self-cleaning to recharge the ink system before doing anything else with the printer.
Note: if the scanner unit is open for more than 10 minutes, the cartridge carrier will move to the home position. If this happens, close the printer and then lift up the scanner unit again.
For pictures, see http://usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx360?CMD=MIXED_SEARCH&mName=PIXMA+MX360&mType=PIXMA+MX&pageKeyCode=ekbresults&searchString=replace+ink+cartridge&BASIC_SEARCH_CURRENT_TOPIC_ID=1077&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=10&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false . Alternatively start at: http://usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx360#ServiceAndSupport and search for replace ink cartridge.
I hope this helps.
May 01, 2012 | Canon Pixma MX360 Printer
My canon Pixma MP 780 says "ink wate near full". What can I do?
There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Closethe lid and the printer should now function normally.
Jul 11, 2011 | Canon MultiPASS MP700 All-In-One InkJet...
How do I change the ink on my Canon MX320
Just open the top cover together with the scanner bed.
When the cartridge carrier move in the middle of the printer, that is the time you can replace the catridge. Lift up the top cover for the cartridge carrier and then the cartridges.
When replacing the cartridge. Push the cartridge down the carrier, you will hear a snapping sound. Return the top cover for the carrier and the scanner bed.
May 20, 2010 | Canon PIXMA MX310 All-In-One Printer
Carrier stall.
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Nov 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Clear carrier jamed
Solution:
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Clear the carrier jam
Solution:
Sep 01, 2008 | Dell 942 All-In-One InkJet Printer
CLEAR THE CARRIER
Solution:
Aug 19, 2008 | Dell 924 All-in-One InkJet Printer
How do I change ink cartridges on a canon pixma mp 130?
just open the front door(your printer should be power on) the cartridge carrier will come and stop in the middle, just take out the cartridge and install the new one
Jul 21, 2008 | Canon Office Equipment & Supplies
Canon pixma mp 210 printer
i am getting a constant "E 4" alarm for fine print cartridge in position/ However when i turn it off then on to get the cartridges to auto move over to accessible location they do not. they remain hidden behind the right hand side even tho the printer tries to move it. i found a foot long lenght of plastic strip and a splver piece of metal loose inside. feeeling atop the cartridege they appear to be in tightly. they mechanism to move them across does not work. is it worth shiooing to mfr or can i get some repair ideas from you> thanks
Jul 14, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
old marine
old marine
