Question about Canon imageRUNNER 3035 Black and White Copier
How many copies can you get out of the life of the copier? million?
  • 1,110 Answers
The answer to your question, it really depends on a number of factors. Generically speaking copiers such as the Canon IR3035 can run at least 1 million copies. Of course this depends on how well they are maintained over their lifespan. A poorly maintained machine will not last as long as a properly maintained one. Also speed is a major factor. For the most part smaller, desktop machines say in the 15 page per minute or less range tend not to last for more than 200,000 pages. Some far less than that. Where a 75 page per minute machine will last at least 2 to 3 million pages if maintained properly.
I hope this helps to answer your question. If you need more information lease feel free to follow up here.
Thank You for using Fixya.
WheatlandServices
Posted on Dec 30, 2010
How to reset the counters of the dev unit of konica minolta c360
The developer unit has been reset automattically,after change the old unit another new.You can change the developer unit life STOP after 45000 copies or NOT STOP more 400000 copies.To change the unit life press:
Utility - Meter count - Check details - Stop - 0 - 0 - Stop - 0 - 1 -Stop - 0 - C - select IU life stop setting touch NO STOP.
Aug 06, 2013 | Office Equipment & Supplies
Error light blinking Citizen -S300 printer
  • High-speed (200 mm/s) printing
  • Longer cutter life (2 million cuts) delivers lower maintenance costs
  • Greater reliability delivers longer life & lower maintenance costs
  • Wider paper width allows printing of additional information & larger fonts
  • Interchangeable interfaces
  • 2D barcode (QR-code and PDF417) support allows wider applications
  • Built in buzzer provides audible alert without adding extra cost devices
  • Built in power supply eliminates unsightly "brick" and frees up space
  • Cash drawer kick-out external device port supports 2 cash drawers
  • 2-color printing supported (when specified paper uused)
Aug 16, 2011 | Citizen CT-S300 Printer
What is the expected life of the M20i, before things start to break down. ie: scanner head etc..
This is a very good machine. The self life for the machine depends on Xerox when they end the service life.
The Copy machine is like a car, as long as you keep up the repairs and replace the worn out parts, it will last for a long time.
What you have no control over is if the plastic starts to fall apart due to time. Especially in the main frames. Stress cracks on parts that cannot be replaced.
Otherwise it can go on for a very long time.
Good luck.
Nov 06, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Date of manufacture toshiba 2860
1997.
OPC drum life estimate 80.000 copies,Toner 7.500 copies,Developer replace every 80.000 copies.
Oct 07, 2009 | Toshiba 2860 Copier
Canon 3220 I/R Jams, leaves blue/yellow streaks
Hi i am a canon technician that do a lot of work on these machines, i have seen many of these machines do over 1 million copies and rarely break down they usually are very reliable,
your streak colour problem sounds like it needs a ITB cleaning blade, if you open the front cover and release the waste toner bottle it sits in behind there just undo one screw and slide it out have a look and see if the blade is yellowish if so you need to replace it. Photocopiers are made to work all day they never need to rest, just rememeber these machines do have small drums but are good for 40k black at 10% coverage.
believe me get a new technician,
feed rollers in trays are good for 100.000 prints i like to change them about 60,000 copies but seen the feed rollers to 100,000 many times.
Prob the biggest problem with these machines when first realesed were low fuser volume about 80k and pretty stuffed heat rollers but they have fixed that issue now.
hope all this helps,
p.s. Ring canon direct they will give you a good local dealer to deal with
Regards canon Tech
Apr 02, 2009 | Canon imageRUNNER C3200 Copier
E030 err on statrt
• Total copy counter (open circuit)
• DC controller PCB (faulty)
Feb 06, 2009 | Canon NP 6050 Copier
Poor copy quality
there are 3 reason if the copy gray & less sharp:
1) the toner you are using is not compatible very well with the cartridge unit if you changed other compatible toner.
2) the cartridge going near the life-cycle, (also cause print blurred)
3) the photo drum going near the life-cycle
you may try to change the quality toner (original factory). or
change the cartridge if it is out of the life-cycle
Jan 09, 2009 | Dell 1600n All-In-One Laser Printer
Canon NP 6050 Copier - number of copies
I would say that is not the correct meter. The meter is only 6 digits long, maybe 7 it's been awhile scine I looked at one. You probly have a meter of 0136012. There is only one hard counter / meter in the copier. It's not even the serial number?? Good luck
Apr 30, 2008 | Canon NP 6050 Copier
Canon imageRUNNER 3035 Black and White Copier Logo
144 people viewed this question
old marine
old marine
