Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't start, light comes on
The dryer stopped in the middle of a cycle. The light comes on, but when I pull the start knob nothing happens. I already tried replacing the thermal fuse and high temp thermostat. What else should I check?
  • tkatt Aug 19, 2008
    Yep, I ahve the same problem with the same model, the Atlantis series (MDE6400AYW). I set the timer, pull it out, and you can hear the timer running, but no proper action of the dryer at all. I have replaced the electircal cord, gone through all of the troubleshooting steps, and still no luck.
    Any further advice will be greatly appreciated, so that I can fix it myself. Service calls are way too expensive.
  • Anonymous Dec 04, 2008
    When I pull the knob on the front the light turns on but the dryer will not start.
  • 943 Answers
Hi thanks for the question the thermal fuse fails allot caused by poor venting yo the outside this fuse is located in the front on the air duct thanks the appliance doc
Posted on Sep 18, 2008
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Kenmore 600 series dryer won't start. Interior light comes on
Strong possibility your dryer fuse has melted due to a lint buildup in the filter chute of your dryer. Check out my photos of a dryer tuneup I did last summer. ROPER DRYER TUNE UP
SERVICE MANUAL AND MORE PHOTOS
Jun 16, 2012 | Dryers
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Eurotech dryer. ON light flashes on and off, beeps once, and still flashes then nothing happens, dryer won't start. Help?
The problem is that you stopped a cycle before the program knob reached the "STOP" (12 o'clock on the knob). All you have to do is turn on the machine, turn the knob to STOP, and wait a couple of seconds. You'll hear a tone and the ON/OFF light will stop blinking. Turn the program knob to the cycle you want and- viola! you're good to go!
May 20, 2010 | EuroTech EDC158 Electric Dryer
Dryer won't turn on...
Try pushing the breaker pair off, then on and re-check the dryer. If still nothing, pull the power plug and check the two slanted slots for ~220 volts AC. If you don't have access to a voltmeter, or a friend with one, call an electrician to check. If you read the voltage stated, then the problem is within the dryer. Check the back of the machine for a reset button.
Sep 14, 2009 | Dryers
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Wash cycle does not start!
if only rinse cycle work. it mean the cycle timer in no good. you need to replace it. i will tell you the cost of it later.
Feb 05, 2008 | Whirlpool LTE5243D Top Load Stacked...
Maytag Atlantis MDE7400AY Electric Dryer Logo
111 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
