Question about Whirlpool Duet GHW9150P Front Load Washer
Getting a f 21 on display - Whirlpool Duet GHW9150P Front Load Washer
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
f21 is a long drain issue..
if you take off the lower cover and to the right, you will see a big round plastic cap. unscrew that cap,
WATER WILL COME OUT, clean out the unit.. put back and your problem should be solved
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 30, 2010
Hi Washing machine BOSCH Maxx 7. Displays error F 21. What's wrong - and what can we do ? sincerely,Jette
The F21 error code indicates that you have a problem with the washing machine's motor.
Have it checked out by competent electrician.
Feb 22, 2015 | Bosch Washing Machines
Green light but won't start
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jun 14, 2014 | Neato 945-0041 XV-21 Robotic Vacuum...
Select #21 on CDg to play in rsqhd787 . What do I key in can't get past #19
In your program, just hit the "Next" button until 21 is displayed.
Mar 15, 2014 | Computers & Internet
Kenmore he2plus what's troublecode f-21
F21 on the tech sheet says Long Drain If the drain time exceeds 8 minutes the water valve turns off.
NOTE: After 4 mins the "Sd" error will be displayed then 4 mins later the f/21 error code will be displayed.
Press Stop two times to clear the display.
(Solutions:) Check drain hose
unplug washer and check electrical connections at pump
Check filter for foreign objects
If these fail it says to replace pump.
Dec 11, 2011 | Kenmore Washing Machines
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Water isnt sucking out
code 21 means
Long Drain
if the drain time exceed eight minutes,"F 21" will be displayed, the water valve will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine.
The display will cleared and the machine will turne off after a maximun of eight minuts.
Was this helpful?
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
F-21 on my window
F21  mean LONG DRAIN if the dreain time ixceeds 8 minutes the water valve turn off. *After 4 minuts the "Sd" error will be do;[;aied tjem 4 minuts later the        F/21 error code woll be displayed. * Press STOP two times to clear the display.
if this wont work the following mus be done by a technician.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
Need to Add Dates in Excel
Here is one way I just tried:
Say the date purchased is in A1.
You want the Est Life in A2.
In A2 type: =A1+(3*365)
That will add 3 years.
For 5 years: =A1+(5*365)
Try it out!
Note: You will need to format the cells to Custom>mm/dd/yyyy
Nov 21, 2008 | Microsoft Excel for PC
Samsung Plano 21
Hai
 My "Samsung Plano Dnie Jr Tv " is Screen Problem.Tv Display is Fully Blackish color and display center is One White Line will be come.
Jun 28, 2008 | Televison & Video
Whirlpool Duet GHW9150P Front Load Washer Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
