Question about Frigidaire GLER341A Electric Dryer
The dryer starts up and seems to run fine except that it doesn't heat.
  • Frigidaire Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 31, 2010
TC470 dryer. Heater doesn't work. Drum, fan all seem to work except no dry heat.
hi Haas.
there could be a couple off things wrong here.
so i think it best you go to this link and have a read up on what it could be.
plus there is youtube videos on here that might help you out as well.
TC470 dryer Heater doesn work Google Search
Dec 01, 2017 | Dryers
My Blomberg 1330A stopped heating. Heating element seems fine, so now looking for the thermal switch...
Test the heating element with a meter for continuity with a meter.
After that follow the wires, one thermal fuse should be neer the heater element the other near the exhuast.
Jan 12, 2013 | Dryers
Hello, my dryer doesn't dry the clothes. What seems to be the problem and how can I check it on my own? Is it the heather, the thermostat or something else? The machine works fine except that its not...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Dryers
I have a whirlpool dryer that won't start. I am renting and the owner doesn't know the model number. The power to the house went out and everything came back on except the dryer. I checked the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 06, 2011 | Whirlpool LGV4634JQ Gas Dryer
The dryer turns on seems to work fine except it doesn't heat. Takes at least 2 hrs to dry a load.
heatman101';';
Jun 29, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
It just stopped heating
If you have a gas dryer the burner is ignited by a eletroniic ignitor. It will make a ckicking noise upon starting it when set in the heat mode. You should hear the click or clicking noise it makes within 30 seconds after starting the dryer. If no click is heard, replace the spark ignitor
Mar 30, 2010 | Dryers
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Frigidaire Gas Dryer not heating up. Other elements are all ok.
It sounds like your igniter is no good. At all costs, check the Fuse before anything else. It is usually accessed from the back of the unit.
Nov 25, 2008 | Frigidaire FGQ332ES Gas Dryer
Frigidaire GLER341A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
