Question about Sega Genesis Console
My genesis only gives me a black screen when I turn it on. I have the game in there, and it's clean. I have look inside, though, and that does need cleaning. How do you suggest I do so?
  • Sega Master
  • 424 Answers
Well I think that the gamepack is broken then.
Posted on Apr 20, 2012
mlake33
  • 427 Answers
SOURCE: How to clean the contacts inside the Genesis.
Honestly, especially with those older consoles, I wouldnt trust any type of liquid with it.
Posted on Apr 03, 2008
SOURCE: sega genesis 1993 model broken, no picture, just black
fixed it
Posted on Jul 01, 2008
SOURCE: Sega Genesis not showing a picture
As I had just a similar problem with my MegaDrive/Genesis maybe this helps: Try an older TV set. I am not joking. It might very well be the case that newer TV sets/high-end TV systems can't handle the signals of the older video game systems. I have a 100 hz TV set and whereas there are no problems with a SNES, with the MegaDrive I just had a black and white screen with bars running through it. On a 60 Hz TV set this problem does not occur. Keep in mind that there were no 100 hz/HDTV sets around when these video game systems were in general use.
Posted on Aug 12, 2008
  • 84 Answers
SOURCE: Sega Genesis not displaying correctly
mine did the same thing. check the video cable, make sure it's in good condition and try to repair RF switch as best as you can.
Posted on Jun 24, 2009
  • 6 Answers
SOURCE: Genesis model 1, periodic static flashes cover the
Have you tried a different TV set? this would narrow down your problem to either the TV or the console.
If you think it's the TV try unplugging all other inputs - unplug the aerial, DVD player etc and see if this makes the difference. (don't forget where all the cables go afterwards!)
If you're really stuck but own a computer, you are legally allowed to download an 'emulator' which turns your computer into a Genesis.
Then you can search the internet for 'ROMs'. These are files that the emulator can read like a cartrage.
Note you are only allowed to download ROMs of games you already own. Downloading other ROMs is illegal in most countries. Also be careful for viruses, some of the sites out there are a little dodgy.
I know this doesn't fix your problem but might offer an alternative solution.
Posted on Aug 25, 2009
Sega genesis model 2 black screen
Well take all your game cartridges clean inside on the chip board thing you see that connects to system to make game play..take rubbing alcohol with q tip clean them all both sides .let dry bout few minutes..make sure console ain't dusty kinda blow it out a little...mine do same thing when stored..after games clean keep trying them ..it will get them to start working ..good luck
Aug 12, 2013 | Sega Genesis 2 Console
How can i fix my genesis?
Sounds like it overheated and melted something inside or clean the cartage
Mar 04, 2012 | Sega Genesis Console
My Sega Genesis turns on and the screen turns black but no picture. Any suggestions?
You may have a dirty cartridge in your hands, try cleaning the contacts with rubbing alcohol, use a cute tip and let dry, then try again. If still problem persist try to clean the console itself following the same procedure, best of luck.
Feb 02, 2011 | Sega Genesis Console
My Sega Genesis turns on and screen turns black but no picture. Any suggestions?
You may have a dirty cartridge in your hands, try cleaning the contacts with rubbing alcohol, use a cute tip and let dry, then try again. If still problem persist try to clean the console itself following same procedure, best of luck.
When I turn on my Sega Genesis, a black screen appears on the TV and nothing else happens. It shows nothing but a black screen. When you turn on the console you can hear it try to start with no success.
Well try cleaning the game packs out with quips and rubbing alchal the game packs could just be dirty then I had a problem with my sega it would just show a black screen when I turned it on so I cleaned out the game packs and it was fine after that the worst case is that your sega is on its way out let's hope not but lukie games sells sega products too.
Aug 27, 2010 | Sega Genesis 2 Console
I recently plugged in my Sega Genesis (MK-1601) console and purchased A/V cords to hook to my tv. When I turn the power on (the red light goes on), I usually just get a flash across the screen and then a...
This is pretty common. The games just need a good Q-Tip cleaning, and then the weird clean pencil-eraser rubbing.
Get out a Q-Tip, and rub it inside the game, on the copper part (The part you stick down into the system.). Keep doing this with new Q-Tips if the old ones get soiled with black stuff. After the new Q-Tip comes out white, it should work.
Sometimes, that isn't enough. Use some Windex or any other rubbing alcohol, dip it onto a Q-Tip, and rub it onto the copper part. Then, use a dry Q-Tip to dry it off, and let it sit out of it's case and out of the system for about 20 minutes so that the alcohol dries.
If that doesn't work, use a pencil with a clean pink eraser at the tip. Rub it inside the game, and use a Q-Tip to get all of the eraser shavings out. This breaks the electro-static cling/friction made when the game is being read by the system.
And if none of that works, go on Amazon or Ebay or to the store Slackers and get new video and AC wires for the Genesis. Sometimes that's all it needs!
I really hope this helps!
Aug 05, 2010 | Sega Genesis Console
My sega flashes on screen but wont come on
Video game cartridge terminals and the console connector pin require servicing similar to this service.
Please let me know how I may assist further.
Apr 19, 2010 | Sega Genesis Console
Sega genesis isnt working...
Have you cleaned the Sega? What I mean is where the casset game goes. Push down the little flap, and there should be a little strip with contacts on the inside. Just clean it with a cotton swab and alcohol. And also, clean all your games also the same way.
Hope this helps.
May 09, 2009 | Sega Genesis Console
Problem with the 1st generation sega genesis
If the screen changes (From snow to black or something) when the console is turned on it sound like the console is partially working. Try cleaning the Cardridge pins que tip and some sort of cleaning fluid.
Once this is done insert and eject the cartridge several times then repeat the cleaning process on the cartridge. Hope this helps.
Jul 10, 2008 | Sega Genesis Console
Jun 18, 2008 | Sega Genesis Console
Sega Genesis Console Logo
93 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
