Question about Trendware TEW-652BRP Router
Can't connect to the URL 192.168.10.1 that trendnet provides?
What does a Trendnet do?
TRENDnet solutions network the countless devices which enable your connected lifestyle and workplace. From the network core to the periphery, TRENDnet's expansive product portfolio includes Wireless, Wired, Surveillance, Connectivity, and Peripheral device categories.
Mar 02, 2015 | Trendware TRENDnet TFM 560U (TFM-560U)...
Tip
Knowledge Base for Trendnet Routers
Hi guys,<br /><br /><br />Here's an easy way for you to view troubleshooting to all Trendnet router/devices for free without going to any site that might give you possible virus.<br /><br />This is the official Trendnet website that can assist you with all your drivers in their products<br /><br />Here's the link:<br /><br />http://www.trendnet.com/kb/default.asp<br /><br /><br />This site provides technical support of you do have problem with your device<br /><br />Click on this link or copy and paste the complete link into your browser.<br /><br />If I could be of further assistance, let me know. <br />Thanks,<br /><br />LETMEFIXIT
on Feb 04, 2011 | Trendnet Wireless Home Router TEW651BR
Cant connect to my trendnet ap653 using 192.168.10.100
Are you connected with a Ethernet cable to the computer you are using to do the setup? Try Trendnet Support : http://www.trendnet.com/support/kb/
Feb 24, 2013 | Computers & Internet
How do i cable 10 computers, a docsis 3.0 modem, 8 port edgewater 881 router and 5 port trendnet TEG-S5G unmanaged switch
Connect 7 computers to the 881 router. The last port on the 881 router go to Trendnet switch. Connect the last 3 computers to the Trendnet.
Feb 11, 2013 | Computers & Internet
Trendnet TEW 6528RP connection
Take a look at the online manual:
www.trendnet.com/download_manager/default.asp?iFile=12474 under the password section (step 5). Try enabling a password under WPA and enter it on your iphone.
Jul 07, 2012 | Trendnet TEW Computers & Internet
I got not internet access
O_O Can you connect via ethernet without the router? Try turning off ALL security in the router. Is this your router: http://salestores.com/trendw64.html
Here is your manual: www.trendnet.com/download_manager/default.asp?iFile=2817
Other than that, you havent provided enuf info.
Dec 03, 2009 | Trendware TRENDnet TEW-435BRM 802.11g...
How to change password for Trendnet TEW 432BRD wireless router
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Trendware TRENDnet TEW-435BRM 802.11g...
Cann't get my wireless router to work,don't understand how to config the router.
HI helock,
This is a step by step instructions:
Note: It is recommended that you configure the Wireless Router from a wired
computer.
1. Open your web browser, type http://192.168.10.1 in the Address bar, and then press Enter.
2. Enter the User Name and Password, and then click Log In. By default: User Name: admin Password: admin
3. The Wizard will automatically appear. Click Wizard if the Wizard does not automatically appear.
4. Click Next.
5. Select your Time Zone and then click Next.
6. Click Next. Note: Do not change default settings unless it is conflicting with your existing hardware.
7. The TEW-432BRP will attempt to auto detect your Internet connection. Follow the wizard instructions and continue on to step 9.
8. This screen will appear if the TEW-432BRP is unable to auto detect your Internet connection. Configure the settings based on information provided by your ISP.
9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection type may have different options.
10. Click Next
Note: It is recommended that you enable encryption on the wireless router. Please refer to the User Guide on the User's Guide CD-ROM for information on
setting up encryption on the wireless router. 11. Click Restart. 9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection
11. Click Restart
12. Click Close.
13. Wait 30 seconds while the router reboots.
14. Verify that the following panel lights are on: LAN, WAN and WLAN.
15. Open up your browser and enter in a URL (e.g. www.trendnet.com) to verify that you have Internet connection.
Your configuration is now complete.
Good Luck,
And don't forget to leave a rating
Thanks
Mark
Sep 14, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Computer says no network connction
Hello greydolf,
The trendnet router emulator web page may provide some assistance for configuring the network connections. But first, it's best to make sure the basic setup is is correct. Please review you current configuration and make sure everything is hooked up according to the instruction booklet. Then reboot the pc. This is the trendnet help/status web link: http://www.trendnet.com/emulators/TEW-611BRP/TRENDware%20MIMO%20Wireless%20Router%20%20Help%20-%20Status.htm . I hope this web site can help you with the router connection issue.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 30, 2009 | Trendware Computers & Internet
Manual Setup of Trendnet Router
1. Open Internet Explorer 5.0 or above Internet browser.
2. Enter IP address http://192.168.10.1 (the factory-default IP address setting) to
the URL web address location.
3. When the following dialog box appears, enter the user name and password to
login to the main configuration window, the default username and password is “admin”.
Jan 12, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Trendware TEW-652BRP Router Logo
405 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
