Question about Kenmore Dryers
I have a Kenmore gas dryer. We have moved to Mexico. Will it run on propane gas? What adjustments will we need to make?
  • kgbelmo Dec 30, 2010
    Yes, just what I needed to know.
  • Kenmore Master
  • 43,501 Answers
Yes!!! You can run it on Propane with the installation of an LP or Propane kit...
The best way to get the kit is to check on the Kenmore (Sears) website... look up parts for your dryer and then find the conversion kit for your dryer...
You can also call Sears Tech. support and they can find and order for you the appropriate kit...
You will need to have the model number and maybe the serial number of your dryer when you call...
heatman101
Posted on Dec 30, 2010
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
How do i convert gas dryer to propane kenmore elite
kenmore has instructions along with the correct orfices you need to burn propane the only difference between gas and propane orfices is the hole size in the center of the orfices and there is very little difference in size propane is smaller hole because the pressure difference between natural gas low pressure proppane higher pressure
Jan 13, 2013 | GE GFDS350GLWW Dryer
On a model 62841, how do you switch from propane to natural gas
Natural gas usually runs on 4 ounces of gas pressure. It is regulated at your gas meter. If you had an orifice in your propane line all you should need to do is remove it.(inside a connector by the dryer intake for gas) Just make sure you look at the back plate of your dryer or user manual and check the pressure rating.
Jan 07, 2011 | Kenmore Dryers
Gas dryer wont heat
Look for air restrictions and clean that up if any. Then inspect the dryer for failed components: e37536f.jpge82d1d0.jpg05795e2.jpg718f5ff.jpg
Jul 27, 2010 | Kenmore 74602 Gas Dryer
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
Kenmore gas dryer works but no heat, model# 110.20702990.
make sure the exhaust vent is not plugged. shut gas off, disconnect hose, start dryer. stop and reconnect hose turn gas back on and try again.
also a propane dryer can work on on natural gas but it is very dangerous to run a natural gas dryer on propane because the orfice is too big.
Sep 23, 2009 | Dryers
Kenmore Series 70 Gas Dryer not getting hot enough
The first thought I have is about the gas supply. If you had natural gas at the old house and now have propane or visa versa you need to change the orifices in the dryer as gas flow is different. Also, if the gas line some how got a kink in it when the dryer was being installed that too would restrict the flow of gas.
Jul 06, 2009 | Dryers
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
Dryers Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
