Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
The SaniPlus toilet was just installed in my basement about a month ago. The water and waste will not go down. The motor continually runs, but the water level does not go down. Could it be blocked or is this a motor problem?
    Scholar:
  • Saniflo Expert
  • 115 Answers
There could be a blockage somewhere in the drain pipe or inside the pump casing not allowing the waste to be pumped out. Refer to the installation manual/technical data manual and take a look at the schematic diagram for the Saniplus, It will show every component inside the pump casing, the short discharge pipe (# 7c) and long elbow (# 8) may be split open or not attached properly and waste water is just cycling inside the pump casing and not pumping out.
Posted on Jan 11, 2011
Pump not running
Check the GFCI breaker at the outlet, if equipped, or if there is a dedicated circuit breaker at main panel box. DW
Jan 21, 2014 | Saniflo & Saniplus& Macerator Pump
Saniplus pump sounds like a jackhammer
I'm glad you asked today, and not 3 months ago!
We also have this model, and ours is hooked to a septic tank, and with a whole lot of trouble, I believe we have your answer.
It is: Toilet paper.
You can pull up the Sani-flush people on line, and they will help you disassemble your unit and clean it. You should find it bound up with a big wad of toilet paper. The newer toilet papers, particularly the softer/gentler/stronger ones, are more glue than paper, and will clog up everything. After our latest go-around a few months ago, we had to go to some stores and buy an assortment of toilet papers, and put samples in glass jars with water, and shake them, to see which would disintegrate, and which stayed together. Because of this, sounds like you will find this the problem. Best not push the motor, or it may burn up, and be quite expensive to fix.
Be blessed,
Dec 24, 2013 | Saniflo & Saniplus& Macerator Pump
Water keeps flowing back into the macerator
There should be a check valve installed in the discharge elbow, check if the check valve is installed or it might just be stuck open so when waste water is pumped out, it slowly drains back into the unit creating water pressure that is making it kick on and off.
Oct 07, 2012 | Saniflo & Saniplus& Macerator Pump
Sanipro continuously runs,however, not pumping waste away and waste water has filled toilet bowl. Any suggestions
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
Dec 23, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniplus- after flushing wc, motor continues to run and run.
climatizarea nu functioneaza in sensul ca nu am aer rece ci doar aer cald
Apr 21, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
This was just installed. When it is flushed the
If there is a air emiten valve on vent ? Remove it than try to see if it works properly. If this works you will need pipe vent outside
Dec 21, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Waste coming up shower trap
Installed in a basement I assume. You do indeed have a clog (before it reaches the maserator).
Aug 31, 2009 | Saniflo & Saniplus& Macerator Pump
Basement up flush toilet systems
sorry Fran,that is what they run.thats just for the unit don't forget install cost too.good luck with this project.
Mar 29, 2009 | Saniflo & Saniplus& Macerator Pump
My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
562 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
