Question about Kenmore 98702 Stacked Washer/Dryer
My kenmore stacked washer/dryer has a wash cycle that can last for 12 hours. it will ultimately finish and clothes will be cleaned properly but it takes long breaks during the cycle.
  • 312 Answers
The time it takes to do a cycle is determined by the washing machine timer. That is driven by a clock motor. This is an older machine so what is happening is that the motor on the timer is stopping and starting. A replacement timer is sold only as a complete assembly. I'm fairly sure you washing machine does the best job in the world in cleaning cloths.
Hope this helps,
Best,
Mark
Posted on Dec 30, 2010
Testimonial: "Thank you so much for your time Mark. I'm going to look into finding myself a new timer. I really appreciate your guidance! Happy New Year! - Doug"
  • bell_doug Dec 30, 2010
    so the clock motor dictate the long breaks the machine takes when it is doing nothing?
  • Mark Freedman
    Mark Freedman Dec 30, 2010
    HI Doug,
    I didn't understand that it was doing nothing. But there are breaks in the cycle of a washing machine. When it goes from wash to spin to rinse and back again through the cycles, there are pauses in the interval. These are silent. If you clock motor is hanging up in these, then it will take much longer to complete the cycle. If the washer is doing all of the cycles and none are skipped, then the switches inside the timer are doing their job. If the machine , for example. is washing but not spinning, the timer is shot.
    A timer is, unfortunately, an expensive part. Usually would cost the consumer around $100.00 to replace these days.
    If, for example, the timer motor starts and get, lets say hot and ceases. then cools down and runs again, then it is going bad but still limping along.
    A washer timer really is controlled by a tiny clock motor. The timers and the moters that run them are purchased from sub contracting companies that make them for Whirlpool and Kenmore and just about every one else now. If you get the model number off of your timer, and get the cross references from a supply house. You may be able to find one like your, on ebay for just a few dollars. Easiest bet is to set aside funds for a new timer, and have at it. The timer on that machine should have easy farily easy access. I used to perform
    intracate unofficial repairs on things that "couldn't be fixed" . One of the things I did with these
    motors was to drill a tiny hole in the gear housing and spray a lubricant into it. Sometimes, but not always it was enough to bring back life to a dying timer motor.
    I hope I have advised well.
    Feel perfectly free to corrispond with me on the this site.
    Best Regards,
    Mark
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Clothes getting caught on inside of dryer
There are a couple of guide wheels in the back of the dryer. when they get worn out the tub will have excessive play and will trap clothes inside. Just remove the front cover loosen the belt and remove the drum. the worn wheels will be easy to spot. It is an easy and cheap fix.
Nov 02, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Washing Machine
Possible faulty valve or internal blockage. Regards Engineer
Jul 23, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
276 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
