Question about LG Washing Machines
The code light comes on with LE. What is the fix please?
  • LG Master
  • 1,902 Answers
Hello & Welcome to FixYa
LE error in your LG washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Posted on Dec 30, 2010
LG washing machine LE code comes up . WD14030D . What can I do to fix it? Claudia
LE code is an overload in motor. You might be washing too many items at one time. Towels are heavy when wet.
Dec 29, 2015 | LG Washing Machines
2004 toyota le check light is flashing what does that mean?
-Use scan tool to read the code and find out what cause that and
fix it.
Good Luck
Mai
Mar 30, 2015 | 2004 Toyota Sienna LE
HOW TO FIX LE ERROR CODE ON SAMSUNG DISHWASHER DMR78AHS
An LE error code on your dishwasher stands for "LEaking."
There is, what I call, a drip pan on the bottom that the water is dripping into. Remove your dishwasher and take off the lower the side panels to get a look inside the drip pan. If you have water in there, try to find out where it's coming from.
If there are no signs of water, tip the dishwasher over on its side and remove the plastic panel on the bottom of the dishwasher. Once removed, you can disconnect the connector to the leak sensor (it's mounted upside-down, with 4 wires coming out of it. If I remember right, the wires are blue and red).
Flip the dishwasher back upright and plug it in and see if your LE error code pops back on. If it pops back on, then you have a bad board. If it doesn't, then you either have a leak, or the "fangs" on the leak detector are shorting out, somehow.
Oct 29, 2014 | Samsung Dishwashers
Fix LE error for LG washer
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
Oct 07, 2014 | LG WT5070CW 4.7 Cu. Ft. Ultra Large...
Washer gives the LE error when trying to spin. What is the LE error and how can I fix it?
Unplug machine, hold down the Start/Pause button 5 seconds while still unplugged. Plug back in and then do a rinse/spin to see if LE code come back.
Nov 19, 2010 | LG WM1814CW Front Load Washer
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Le error code
IE means that it is taking too long to fill up.
May 28, 2009 | LG WM-0532HW Front Load Washer
When I start a cycle after a few mins I get LE error code
I had a similar problem Check the wires a black wire was shorted in the door. Heat broke the insulation down. George
Mar 01, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Washing Machines Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
