Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
A few more questions.
1. Is there a way to take it apart? I see no screws on it.
2. When it is plugged into a power source, there is this odd ticking noise, as if power is trying to reach it, but failing.
3. The power is transferring through the adapter at about 12.1 volts. It was tested by a FLUKE True RMS Multimeter. Is the adapter the problem?
    Sergeant:
    Champion:
  • 250 Answers
These cases are normally friction fit or they have little slots for the air to get in. If you put a small flathead screwdriver into these air slots on the side sometimes there are clips in there you can push on that release the two plastic halves from eachother.
If the power source isn't putting out enough power it could be the motor trying to spin up or the reading arms trying to move on the drive. I would not try to use it anymore until you get the drive out. You don't want to do any damage to the drive.
If the adapter is putting out enough juice it could be something in the connection from the adapter to the drive. I would still get the drive out and check it to be on the safe side.
Posted on Jul 08, 2008
How do I take apart a px40 projector?
1,remove the screws on the back. (only 1-2 screws)
2,force the cover(white) from the back
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 06, 2014 | Sony VPL PX40 Multimedia Projector
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 28, 2012 | Kettler treadmill Pacer
Power turns off and on every few minutes
This model had some odd problems--answers to a few questions might suggest what is wrong
When set is on does brightness come up very slow or is somewhat darker when on?
that might indicate a lamp issue----set will detect if screen not bright enough etc.
With set on is picture normal? (no unusual color in back ground on screen or such? set is prone to light engine failures--the engine communicates with other parts of the set--something not right it shuts down.
My final thought is a power supply problem----this is not a easy set to get apart to service or look for things---for the most part the entire front screen has to be removed to gain access to the boards. Note the lack of many rear screws on the unit.
Nov 07, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
I have an 18volt Dewalt XRP 1/2 inch drill. The drill has been working perfectly up until this morning when I took it froms its case. I was using it the evening before to screw in some 2 inch screws into...
Check electrical contacts in drill body where battery connects. Check wiring inside the drill, trigger and check also brushes. You do not have to invest 329, you can buy "body only" machine for few bucks and reuse your charger and battery packs. Juraj
Oct 20, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My dremel works intermitently. As I move the switch from one speed to another it will momentarlly run. Whats the problem? THANKS
You described intermitten pwer supply, follow this procedure:
1. check your power cord for breaks or kinks, especially where it join the piece or plug
2. if cord is ok, check/replace brushes.
To check/replace brushes on dremel 395 follow this procedure:
1. switch off unit, remove power cord.
2. with flat screwdriver remove gently brush covers, WATCH FOR LITTLE SPRINGS!!!
3. check brushes for wear, springs if connect correctly, if brushes are thinner than 3.2mm (1/8") replace with new ones, this check should be carried regardless after about 50hrs of use, brushes last about 50 to 60hrs in normal use.
In unlikely case that it is switch, this is as well very easy replaceable.
1. switch off unit
2. remove cable from power source
3. remove brushes following previous procedure
4. remove collar from front of the piece
5. remove side screws and gently pry apart halves, label side up
6. replace switch
7. screw pieces back in reverse order
8. replace back brushes.
All parts are easy available, when purchase brushes or switch, be aware that they fit only particular model!
I would recommend clean table with butcher paper on top, torx/hex screwdriver, philips screwdriver, flat screwdriver - these vary from country to country, I cannot provide what exactly tools you will need, you need to check what screws are holding your piece together, little long nose pliers can be helpful as well.
As you pull handpiece apart put your parts in order in whihc you pulled them apart, when you put them back, it will be easy to put them back in reverse order in which them come apart. For changing brushes you need about 5min (assign 15min), for changing switch or faulty power cord you need about 1h (assign 3hrs), assigned time is theoretical, prctically multiply it by 3...
If you have anymore questions, or require more detailed instructions, do not hesitate to follow this thread and leave note.
Leave note how it go, thanx!
Aug 13, 2010 | Dremel Variable - Speed Multipro Rotary...
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP C5180 error messsage Oxc19a0024 will not print. what to do.
Ok this is a old postint but you may come back to see it or it may be handy for some one elles.
Solution 1:
Solution 2:
  17. All the best: Pineworks
Jun 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
Help!!!
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
Mar 18, 2008 | HP Photosmart D7160 InkJet Printer
Phone jack wiring
Its typical in apartments for the phones to come in through a single source and then fan out to other wire leads to the rest of the phone jacks in the place. However, I think its odd that your 'source 2' has 9 wires. I'd expect 8.
One idea is to take off a phone plate in another room and see if the wire colors on source 2 or 3 match the unknown source wires. If so, then just match the wires that connect to the same plugs in the plates.
Jan 22, 2008 | Lands Phones
RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Nov 07, 2007 | RCA L32WD12 32 in. LCD HDTV
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
35 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
