Question about Panasonic HDC-SD20 High Definition Camcorder
Windows xp does not see HDD on camcorder to download using 2.0 version of HD Writer -- should be 1.0 with this camcorder
  • 4,924 Answers
This is not an issue cause if it works on 2.0 it works on 1.0 too ...the other way around is not always a working solution ..
The issue is that the USB connection is for using it in streaming and such ..and you will have to make a firewire connection for download ..If you installed the driver ..and the camera has a firewire connection use it ..and the hdd will be see on my computer as a drive ..or you will have to use a video manager to import from device ...(you can use the windows movie maker...and import from device feature.)
try it and let me know ..If the camera came with a manager software ...install it too and use it ..
Posted on Dec 31, 2010
Hd writer on mac
please check if you are using DVD-R to the hd writer...
if you are using it .then its not possible
You can only use DVD-RW and must format the disc to VR format, not Video format.
Mar 22, 2008 | Panasonic HDC-SX5 DVD Camcorder
Cannot download from panasosonic hdc-tm60 to hd writer, get "no picture can be displayed" message
if you get this massage it is not that you can not download but it can not read them ...so you miss a codec or so ...if you reinstalled your computer recently ..be sure you have the codecs for the format you are getting from the camera ..or ..the hd writer may be corrupted at the codec level ..and reinstalling it may work ..it' worth to try ..if you know that you did not change settings in the camera ..
Try also to download it first on the computer and load the files after ..also see if you can playback the footage with a player into computer and you will know for sure the files are not corrupted and playable ...usually the mpeg2 codec is the one makes such troubles...and it is available for download...
but ..usually panasonic records in mpeg4 compression ..so ..reinstalling the hd writer its the probable fix...
Jul 14, 2011 | Cameras
Have installed HD Writer AE 1.0 for HDC on laptop running Vista. Works OK. Have tried to install on PC running Win 7 but won't load. Is there a way to upgrade software to run on a Windows 7...
If you have the CD with HD Writer AE, justfollow the steps below:
1. Go to the Administrator account and download the update software from: http://cnc.asp.hi-ho.ne.jp/cnc/global_cs/software/win7/Setup.exe
2. Insert the CD-ROM with the HD Writer AE1.0.
3. Double click the Setup.exe you just downloaded, and follow the procedure.
A free alternative to backup videos from camcorder to hard drive without HDWriter AE on Windows 7: Aunsoft Final Mate.
Jan 03, 2011 | Panasonic HDC-SD20 High Definition...
I can not download form HDC-SD20 use by HD writer
I have same problem. I have Panasonic HDC-TM20 video camera. It came with HDWriter ae 1.0 software. I have ACER alptop, running XP. Everything was running fine for months, but now I cannot transfer from the video camera to the hard disk on my computer. It attempts to do it, but then it just does nothing for ages. CPU usage shoots up high. When I kill the application, it does die, but process continues so I need to re-boot mt laptop before I can load it again. Is these any one out there who has resolved this issue?
Nov 12, 2009 | Panasonic HDC-SD20 High Definition...
How do you restore deleted movie files on your computer?
try opening your recycle bin and restore files which you deleted recently
May 22, 2009 | JVC GZ-HD3 HDD HD Camcorder - 60 GB USB...
Problems using HD Writer 2.5E with Vista
I spoke to a technician at Panasonic. He said the problem is the 64bit Vista. It may run with the 32bit version, if gives trouble there is a patch update under Global Support/consumerproducts (digital AV window updates) at Panasonic web page. It will work with new Windows 7.
Feb 09, 2009 | Panasonic HDC-SD9 Flash Media Camcorder
HDwriter 2.5
This is the link for HD Writer upgrade - You need this to install on Windows XP SP3. Very slow download though
Mar 31, 2008 | Panasonic HDC-SD5 Flash Media Camcorder
Panasonic HDC-SD20 High Definition Camcorder Logo
46 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
