Question about Cycling
I need help on a giovanni 125cc dirt bike. when the bike is running theres gas coming out the air filter
  • 927 Answers
The first thing to check is the fuel bowl.
Shut off gas, remove the fuel bowl, clean it out, ensure that the float goes up and down smoothly, turn gas on and ensure that lifting the float stops the gas.
Reassemble and try again.
Posted on Dec 31, 2010
Why dose my pit bike keep fouling sarkplugs
is the bike a2 stroke or a four stroke? regards Ray.
Sep 17, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
125 Pitbike keeps fouling spark plugs
Hi, Damon and the usual suspects are:
1. Dirty air filter.
2. Fuel mixture too rich or the choke has been left on too long.
3. Faulty spark plug.
4. Incorrect spark plug heat range for the engine type or service.
5. Piston rings badly worn or broken.
6. Valve guides are badly worn and/or seals worn, crushed or have come off the valve guide and are pumping oil through it.
7. Spark plug cable weak or leaking check for spark leakage in the dark.
8. Faulty ignition coil.
9. Low RPM nonaggressive riding style.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Why Does My Dirt Bike Keep Fouling Spark Plugs
Spark Plugs Keep Fouling
http://mypitbike.ru/downloads/ThumpstarServiceManual.pdf
https://www.orionpowersports.com/pit-bike-dirt-bike-parts
http://www.ssrmotorsports.com/store/ownersmanual/pitbike/Pit%20Bike%20Owner's%20Manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 13, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
Bike not starting
first try a new spark plug, if you get spark check gas filter, have spark ,have fuel, have timing it should start
Jan 05, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
Dirt bike cuts out on second gear "!!
make sure it has oil, low oil can cause overheating and thermal cutout
Apr 29, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Why my pitbike wont start or cuts out
Yep, clogged fuel filter, dirty carb. ????
Mar 24, 2013 | Pit Bike 125cc 4 Stroke Dirt Bike
Dies at top speed
This is most likely a fuel delivery problem. See if it's a little better if you run it on half choke. If so, there's likely a blockage in your carb. If it doesn't run any better, the bowl may be running dry due to a clogged filter. (Yes, there's a strainer type filter on the petcock in the fuel tank.) Can you slowly give it throttle and get full speed out of it?
Nov 24, 2011 | Pit Bike 125cc 4 Stroke Dirt Bike
250 cc giovanni dirt bike is smoking bad and looks like oil is coming from around the exhaust and oil is spitting out of the muffler
Has the bike been laid over? Could be possible that your air filter is soaked with oil and is burning off( smoke) or being forced out of the muffler.
Aug 15, 2009 | 2008 KTM 250 XC
Cycling Logo
88 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
