Question about Cobra 29 LTD CB Radio
Some peole say turn VR4 clock wise to up your audio otheres say counterclock wise..........which is it?
    Novelist:
  • Cobra Expert
  • 500 Answers
Turn it to the smallest resistance value.
Posted on Jan 07, 2011
How do i set the time on orium clock
Twist the dial to the counterclock wise direction
Aug 18, 2014 | Michelin Orium 700x25 Blk/Gry
To change sawblade on KingCanada 5007. Do I remove bolt clock or counterclock wise
counter clockwise to take off and clockwise too put on, if the bolt sticks out a little ways check with another nut
Jul 23, 2011 | Garden
I dont know how to change the wheel/blade on this DeWalt cut off tool/grinder! Help!
If its a hand held grinder, on the back or the side of the grinder itself there is a button in which you must depress. While depressing it you must turn the wheel at the same time until it locks in place. You have to keep the button pressing to get it to lock.
Once it locks into place, you need a spanner wrench to loosen up the nut (counterclock wise). If you have a grinding wheel on it, some just screw on without a nut. And if this is the case, then just grab a hold of the wheel by hand and turn it counterclock wise and it should come off.
Make sure you unplug the tool before doing any of the above.
Jun 01, 2011 | Garden
Mbbwe are trying to change the wheel bearing assembly, what is the best way to get the nut off. We have tried clockwise and counterclock wise direction and using penetrating oil
couter clock wise righty tighty lefty loosey you will probably need to heat the nut up or you need a half in breaker bar or a 3/4 inch breaker bar .
Feb 18, 2011 | 2004 Chrysler Pacifica
Change sepertine belt on engine.
it is not that fun, you need to have 1/4 inch tools, 10mm socket 8mm socket, 12 mm socket,18mm socket. and wrenches to match. you need to support car on jack stands and remove pass tire. Go to your local auto parts store and get a manual first. as the valve timing is very critical in the installation process !!!!!!!!!!! if this timing is not done exactly you will cause severe engine damage to valves and pistons. read manual and read again then assemble it right the first time as there is no room for error. Belt is 30 -50 $$$ depending where you go.
Jan 11, 2011 | 1998 Ford Escort
Craftsman 25cc weedwacker (358.791030). Zama carburator (C1U-W19) Just rebuilt carb but did not adjust low speed/high speed screws. Starts on first pull (with choke lever actuated), and after warm up,...
need to adjust the high sscrew. i do mine in 1/4 turns. start machine, full throttle, adjust the h(high) til it clears up.i would start by turning 1/4 counterclock wise, just remember to keep track, in case it runs worse, the put it back to orig. then try the other way. but i suggest 1/4 turn at a time
example... think of a clock when turning screw. straight up and down, 12oc, 1/4 turn will be 3oc, another 1/4 will be 6oc, and so on. hope it helps!
Sep 17, 2010 | Craftsman 25cc Gas Line Trimmer
Which way do I turn the main bolt on crankshaft to get main pulley off. I went counter-clock wise and it broke the braker bar.
you turned it the right way but will have to use an air impact to get it loose or a hammer to hit the ratchet or breaker bar with, you need a half inch drive breaker bar to get it loose and it will have to be in gear and the emergency brake on to get it loose.
Jul 15, 2009 | 1995 Isuzu Rodeo
Cobra 29 LTD CB Radio Logo
227 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
