Question about Canon Rebel XT / EOS 350D Digital Camera
Unable to download EOS Solution Disk due to computers low screen resolution'
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
You don't have to use Canon software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Jul 04, 2011
The camera say,s , err 02
Err 02
Description: The camera cannot access the memory card.
Resolution:
  1. Remove and re-install the memory card.
  2. Format the memory card as described in the user manual. The user manual for your EOS camera can be downloaded form the Canon Europe EOS camera support page.
  3. If formatting the memory card does not resolve the error please replace the memory card.
Dec 27, 2012 | Canon Eos Digital Rebel Ds6041 6.3 Mp...
Resolution is not adjusted
My published guide entitled How to set your Desktop Screen Resolution? will enable you to set the correct resolution for your computer. I would recommend a desktop resolution of either 1024X768 or 1280X1024
If you are unable to select these then you need to download the latest graphics driver off the internet.
damnor01
Dec 19, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
I'm not able to download the solutions disk (version 31.1)
Sorry this is a late response - I just had the issue with the T1i solutions disc ver. 20.0. on Windows XP
Right click your desktop and select Properties
Go to the Settings Tab
Under "Display" you should see it is selected to your default monitor or Plug and Play monitor.
Under that, you will see Screen Resolution on the left hand side. If the slide bar will not allow you to change this any higher, then at the bottom of the window you will see an option for Advanced
Write down your current screen resolution so you can change it back after installation is complete.
Click on Advanced - You will see tabs at the top - click on the tab marked "Monitor"
This will show you Monitor Type - under thatyou will see Screen Refresh Rate (ex. 60 hertz)
Under that is a check box marked "Hide modes that this monitor cannot display"
Uncheck this box and click "OK"
This will take you back to the screen resolution and you can change it from there. Change it to 1024x780 - this is the minimum display resolution for the installation disk.
When you have installed the software, you will want to change it back to your normal resolution
Note - if you want to use the EOS utility to download and edit your pictures, you will need to change it back to 1024x780. I just use the Windows Camera/Scanner wizard to download, and then use Adobe to edit the photos.
Hope this helps!
Dec 30, 2008 | Canon Cameras
Screen Resolution
Tried Control Panel and went into Appearances and Themes and then on to Screen Resolution.  Discovered this had been set at low, so I simply increased to download disc and then reverted back to lower size.
Dec 26, 2008 | Canon COLOR IMAGE SCANNER
Canon Rebel EOS - Pictures download read Low Resolution
Canon Digital Rebel cameras let you set the image resolution from small jpegs (low resolution) to large jpegs (high resolution) to RAW (best quality, but require post-processing in your computer before you can print them). It's possible that as you were getting to know your camera you accidentally set the image size and quality to a low setting. Now you just need to change it back!
You make this change in the on-screen menu, under the camera menu (first menu, with a camera icon), first item (Quality). Although Canon no longer has the manual for this camera online, you can see This Review Page for more details on where to change this setting on your camera.
Dec 18, 2008 | Canon Digital Rebel / EOS-300D Digital...
I have just bought a brand-new Canon 450D - a lovely camera, but my computer will not open the EOS Digital Solution Disk (v18.0), quoting: 'the screen resoluion is not sufficient'. My Pc is not THAT...
I managed to alter the resolution on my PC through right-click -> properties -> settings, after some telephone advie from the Canon folk.
Oct 02, 2008 | Cameras
Hi, I just bought a Canon Rebel, and I'm trying to download the EOS Digital Solution DIsck and I'm getting a message that says my screen resoltution is not sufficient? Help.
This is an easy fix.
Go to your control panel. Click start/control panel/display/settings.
There you will find your screen resolution slider. Slide all the way up to high resolution and apply settings. Your icons and everything on your screen will be smaller.
Install disk and go back and set your resolution as low or high as you wish once installed!
Hope this helps!
May 29, 2008 | Canon Cameras
Screen resolution not sufficient to install ver.30.0 software.
I had the same issue with my Netbook. In order to get the software onto my netbook I had to use an external monitor. I set up my HD monitor as the main monitor through the graphics driver. I set the main monitor from notebook to monitor. Then I installed the package and set the main screen back to notebook. I can use the EOS Utility which allows my to download my raw images and remotely control my camera, but I cannot run DPP. I hope this is of help
Apr 19, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Eos digital rebel
Unless I'm missing something, you should be able to plug it into the computer and download. I use a Samsung digital and as soon as I plug it in and set the switch on the camera, turn it on and a helper screen comes up on the 'puter asking what I want to do. I use XP Pro so any of the later operating systems should work. Hope this helps,, Mechanic
Jan 16, 2008 | Canon Rebel XT / EOS 350D Digital Camera
EOS DIGITAL solution disk
clear you computer desktop of misc files. then right click on a blank spot on the desktop. select 'properties' then select 'settings' where you will find the video resolution screen. adjust to a higher resolution in one increment. apply, and if it does not look good to you then revert and take another setting up from that one.
this is an easy function to fool with. there will likely be several choices and they often change the correctness of the image as it fits on your particular display aspect ratio (width vs. hight) and the result will be a not very pleasing image due to shrinking or stretching. also, you may find a setting that your monitor does not like for one reason or another. it could cause your image to become unreadable. do nothing if it looks bad or you can't see it clearly, as it will always revert to original settings on its own unless you tell it you like it. so be sure to hesitate if you are not sure. if you select a setting that your monitor or driver can not handle, you might have an unreadable screen, which makes changing it back very hard.
good luck
mark.
Dec 09, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon Rebel XT / EOS 350D Digital Camera Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
