Question about HP Pavilion dv6000z Notebook
The vents have been cleaned, so have the fans....anything else that can help.
  • HP Master
  • 6,771 Answers
Yes! remove the heat sink from the cpu processor and remove the old thermal conductive grease from the cpu and heat sink, then apply fresh thermal conductive grease to both and assemble, make sure all dust and dirt has been removed from the heat sink fins
Posted on Dec 30, 2010
I have a sony projection tv the model number is KDFE42A10 Work's fine but the picture goes out and green light blink's About 49 times then picture comes back on after a few minutes it do the same thing...
It may be overheating check to see if the fan is running and the vents are not plugged with dust and or lint carefully clean out anything obstructing the vents and make sure fan is operating. Hope this helps.
Jan 01, 2014 | Televison & Video
How do you change the fan in a laptop
Is the fan spinning? Have you cleaned the fan, vents, heatsink using a can of Compressed Air? You may have to dissemble the laptop to get all the dust out. Is the Laptop getting sufficient air flow through the bottom and out the side vents? Is there anything blocking it? A Laptop Cooler is one option. Depending on the CPU, you didn't post your Toshiba Model, there is a freeware program, SPEED FAN: http://www.filehippo.com/download_speedfan/ If the fan isn't spinning, take a look at this: http://www.youtube.com/watch?v=G2AcFvd9qjc
Apr 12, 2013 | Toshiba Satellite Computers & Internet
Nutone bath fan how do you clean the vent
Usually the vent cover pulls straight down, and is held in place with 2 V-shaped metal spring wires.
Squeeze each spring wire together to release cover from ceiling box.
Use vacuum to clean vent fan housing. Some vent fans can be disassembled and motor housing removed for cleaning. Do NOT use water on electric motor. Simple vacuum, or dry toothbrush cleaning is good enough.
Spay tiny bit of WD40 on the fan motor shaft or add tiny dab of white grease if desired.
The plastic cover can be scrubbed with soap and water, rinse to remove soap residue, and when dry, paint with aerosol spray paint using 3-5 very light coats applied in 5 minute intervals.
Jul 28, 2012 | Broan-NuTone Fan,Bathroom Exhaust Broan...
My bathroom Broan exhast w/light makes a constant clicking / tick tock sort of noise when the fan is not running. as soon as I turn the fan on the noise stops and then stops after I turn the fan off, only...
remove the cover and clean anything in the vent , check the fan for anything that could be touching it, as the back draft comes through the vent, something could just be touching the fan blade as this draft makes the blade turn slowly, which would create a ticking noise
Jul 10, 2011 | Broan-NuTone (8663RP) Ceiling Fan
Why my samsung 55" tv over heats only the screan but works creat
Plasma technology produces more heat than other monitor types, as such it has less options for successful placement.
First verify that the cooling fan does in fact operate; it should turn the blades a fast pace.
Then clean any dust from ALL of the vent openings and especially any filter placed in front of the cooling fan(s). Also keep away from the TV anything obstructing air flow through the vents.
Aug 25, 2010 | Samsung PS42P2S 42 in. Plasma Television
My dryer stopped drying our clothes in the past. I replaced the fuse and problems solved. Now same problem replaced the fuse and it heats up then goes out. I cleaned out the hose and dryer everything...
Is it blowing hot air out the vent?. I've seen something like pencils , lint or about anything clog the fan and won't let it turn. The vent must be clean going to the outside of the house. You can take the vent tube off at the dryer and see if it helps if it does out side vent might be cloged.
The operating thermostat might not be cutting off power to heating coil soon enough and getting hot enough to blow fuse. Check all thermostats and any one time cutoffs a one time fuse. Don't know what type dryer or model number you have. When you ask for help always give the name and model or your machine because they are different.Hope this helps.
Aug 16, 2010 | Whirlpool Dryers
My microwave does not vent out moisture well and leaves a lot of moisture accumulating into water at the bottom of the oven and on the door and sides. The vent is not blocked. It just doesn't clear...
The fan that cools the magnetron also helps exhaust water vapor. Does the fan sound as strong as it used to? Is the vent at the back of the microwave clean? Sometimes lubing fan motor bearings with light machine oil will speed up the fan. You would have t remove the cover to gain access.
Jun 20, 2010 | Panasonic NN-H504WF Microwave Oven
The fan motor works, but is not venting the room
It might take some work, but you should be able to get at the exhaust vent by removing the grill, light fixture and fan. Might be best to try and find where it is vented to, hopefully an outside area. If you can, there are some small over the counter type of things you can use to try and clean the vent. One is a window brush that is on a long pole, found in the window cleaning area of the Home Depot. This is a soft brush that will not damage (famous last words) the exhaust vent. There is also a flapper door of sorts that closes at the fan when the fan is not running. Might be that the flapper is stuck in the closed position. Good luck!!
May 14, 2010 | Broan-NuTone N-8663RP Combination Light...
Our new bathroom fan is not clearing the room the ceiling is wet and the paint peeling the fan is model #FV-LP003
I use to be a chimney sweep. One of my jobs was to clean vents for dryers and bath vents. What could be your problem is that you have a bird nest in the vent system. It sounds to me that you have a vent on the roof for the fan. A bird could have damaged the cap to gain entrance and built a nest. With the cap gone, rain can come in. With the nest, it will not vent out the room. You could call your local chimney sweep company and they will clean it for you. Or if you are capable, Lowe's or Home Depot sell dryer vent cleaning rods. They are sturdy but flexible rods with a 4" brush on the end. Two other handy tools will be a high power shop vac to **** out anything from inside the vent, and a high power blower that has vacuum capability to use out side the house. Cafe full though, if it pulls out a nest, it will shoot it out with great force.
Jan 23, 2010 | Panasonic WhisperFit-Lite Low Profile...
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
