Question about Dewalt Round Head Framing Nailer D51845
Will not use the whole stick of nails Breaks the last 3-4 nails from the end Is this normal
  • Dewalt Master
  • 885 Answers
I'm not sure what you mean by "breaks the last 3-4 nails from the end' but because of the damage that can be done by firing an empty nail gun most manufacturers are making their guns stop working when the magazine gets down to the last three nails. You would need to check your operators manual to see if your model is one of these.
Posted on Dec 31, 2010
I have propulse 2 inch Brad Nailer. Model 57265001. when i press switch just air blow out but no nail or nailing
1. Does it have any nails in it? A) add nails
2. Often when you get down to the last few nails it will quit working. A) add more nails, you may have to discard the remaining nail or three before adding more nails.
3. You may have reached the end of a group of nails and the last nail or 2 are jamed up in the end of the nailer. A) Need to open end of nailer and remove jamed nails. Don't forget to disconnect nailer from compressor first.
4. Other options are not enough air pressure, or the gun is damaged and needs repaired or replaced.
Good luck.
Aug 02, 2016 | Air Tools & Compressors
How do I clear a jam?
Hi Gary:
SAFETY FIRST! Disconnect from air supply.
Pull trigger to make sure not "loaded"
- Here's what I would do.
1) Open magazine and remove stick of remaining nails
2) Try to remove jammed nail with pliers, pointy tool, etc.
3) Use allen wrenches to dis-mantle head until everything comes apart and jammed nail falls out.
4) re-assemble, cleaning and oiling at the same time.
Once done, re-connect to air supply and test.
Hint. A 2 inch nail can take some effort to penetrate, especially a knot in hardwood. Make sure you are using adequate pressure; that is the high end of the recommended pressure.
Cheers.
Dec 30, 2015 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
My dc616 dewalt nailer is not firing and constant flash not battery no jambed nails what else could it be
look at the end where the nail comes out . it should be flush across , if the plunger is sticking out then push it back in with a flat screw driver and try again.soft wood quite often lets the nail shoot to far
Aug 13, 2015 | Dewalt DC616 16g Cordless 18v Straight...
What will make your fingernail swell and when you squeze it infecton comes out like a blister with blood?
It might have a foreign object stuck in between your nails. A thorn or a small stick maybe. Or also an ingrown nail that wasnt cut properly and might have cut the skin...It got infected because it wasnt taken out in time. If the whole nail wont come off, please go and see a doctor.. The infection might get worse... Worst event that will happen is they might cut your whole finger if it doesnt get treated as soon as possible.. Treatment with antibiotics.. Oral and injected.. Also cleaning several times a day
Dec 09, 2014 | Health & Beauty
Stanley coil roofing nailer not sinking 3 1/4
That model may not be designed for that length nail. Check with your local supplier.
Mar 10, 2010 | Stanley Bostitch Coil Framing Nailer
Problem accessing nails
Hi, No you can't. They are two different feeds. The F33 uses tape feed and the N79 uses stick feed. The N79 is a basic wood frame nailer that uses 3 to 3 1/4 sticks, while the F33 uses up to 2 1/2 paper feed. The stick nails are the most common for the older nailers and on the box look for Bostitch as the brand to fit, as the N79 was sold under that brand not Stanley. This should Fixya!
Mar 02, 2009 | Stanley F33PT Paper Tape Framing Nail
Makita AN 901 framing nailer blows nose end apart
not too familiar with makita brand nailers but jams are usually caused by cheap nails but I see you have tried senco brand which is a good brand sounds like a mfg defect try using hitachi brand nailers they are good
Dec 26, 2008 | Makita AN901 Coil Nailers
2007 dodge caliber breaks
They're telling you the truth, if they inspected your brakes and didn't find anything wrong, it is normal. I've seen this before...it's annoying, but normal--nature of the beast, brakes=friction=noise. Make sure you get a copy of the service invoice from your dealership that denotes that you brought it in and they inspected the brakes and didn't find anything wrong...it may be beneficial for you to keep these records. The warranty on your brakes is 12 months/12,000 miles -- NOT 36/36 like the rest of your factory warranty.
May 15, 2008 | 2006 Dodge Caliber
Dewalt Round Head Framing Nailer D51845 Logo
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
