Question about LGDVB418 DVD Player
Having a problem with LG dvd player saying check regional code on every dvd i try to play, it was working perfectly a few weeks back but hasn't loaded a disk since.
5 Suggested Answers
jaffa012001
  • 376 Answers
SOURCE: Multi Region Code LG DV380
Open Tray
Press 0 three times and when region menu appears select 0 then press pause
Posted on Sep 08, 2008
SOURCE: LG RH387 HDD DVD Player wil not play Disc's from other Regions.
1. Go to http://hk.lge.com/support/support_lgeservice.jsp
2. Go to "Product Support"
3. On the left panel, find "Device Driver", then "DVD Player/Recorder".
4. Download the "RH3xx.iso" from the linked page.
5. Burnt ISO to a CD (must be burnt as an image, use free software such as ImgBurn http://www.imgburn.com/)
6. Load CD onto the LG player
7. You will be prompted to choose a new region code - go with 0 for region-free
Posted on Mar 30, 2009
SOURCE: Changing region code to all on a LG DV550 DVD player?
icon_minipost.gifRegion code hack posted by hackaroto, December 27 2010:
1. Switch off the DVD player in to Stand By mode
2. Open the DVD tray using the remote control
3. Press "pause" in the remote
4. Enter 0, 0, 0, 0 (zero 4 times)
5. The display should indicate the regional code set in the DVD and prompts for the new regional code.
6. Enter the new regional code
7. Press Pause to exit the setup
8. Switch off the DVD using the remote and wait for a while before switching it on again.
works for other LG DV55X players
Posted on Jan 14, 2011
news775
  • 699 Answers
SOURCE: How do i make my
Try this
1. Go to Menu
2. Press Set Up Button.
3. Scoll down to Lock Highlight & Press.
4. Scoll down to Area Code.
5. Enter 0000 and again 0000 press the pause button.
6. Press Enter.
7. Change the Region Code to any Country you require.
8. Exit
Posted on Feb 07, 2011
How can I change the region code from my BD-270 to Brazil code. When I play US DVD its OK but when I try to play a brazilian DVD it doesn't work - say to check regional code. Thanks, Vilmar
1.Press the Open button on your remote control to open the drive tray
2.Press the 0 button on your remote control seven times, in succession
3.A message should appear on the onscreen display indicating the region has been changed
if that doesnt work try this
Press Setup
Scroll to Lock
Press 0 (7 times)
A message will appear saying it is region free.
these are for a number of LG DVDs if it will work with your blu-ray is another thing, but wont harm to try it
Mar 26, 2011 | LG BD270 Blu-Ray Player
Dvd in player but display says no disk
Check the regional code of the DVD you want to play. It is at the back of the DVD cover. It should be compatible with the regional code which your DVD player can play. If they are not tallying the disc will not be read
Feb 23, 2010 | Toshiba SD-K760 DVD Player
Region code 2 on LG DV492H not playing DVD with same code
You could try to set you firmware to Region 0 (all countries) you can do this with the remote
Eject the disc tray, and while it's open hit 0 - 0 (two zeros) on the remote.
Then enter 0 for the region code (for all regions.)
Jan 11, 2010 | Televison & Video
Trying to play dvd but says wrong region soneynhv-dx350ab?
Hi, if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution. Mike @ Compurepair.
Jun 12, 2009 | LG RC897T DVD Recorder/VCR Combo
Unlock regional code on LG dvd player model DV480
I found the solution here.
http://www.videohelp.com/dvdhacks/lg-dv480/10008
Region code hack posted by vassmanov, March 23 2009:
Press the Pause button on your remote control. Using your remote control enter the code 3,1,4,1,5 and 9, At this point, a blue screen displays showing that you are in 'region altering mode'. Press the 0 button on your remote control for Region free. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player and your ready to go!
It worked for me (after a few false starts)
May 03, 2009 | Televison & Video
Need unlock code for LG V774W
Howdy,
I just tried this on LGV774W and it worked :))
To make this player region free (or change the region), do the following:
* Ensure that there is no disc in the player (ie: "no disc" is displayed).
* Press PAUSE
* Enter 314159
* Enter the region code (0 for region free, or 1-6).
* Press PAUSE
* Turn the player off for a few seconds.
* Turn the player back on
* Voila! You beauty!!
Jan 13, 2009 | LG XBR446 DVD Recorder/VCR
Region code accidentally changed and no idea how to set it back
power on your dvd and press setting as you can view on your tv monitor then check the displayed carefully look for dvd regional settings and change it where you live.
Oct 18, 2008 | Samsung DVD-R155
Need to play region 1 DVD in region 2
hi
try a search on your dvd here check for region codes dvd
riz.
May 31, 2008 | LG RH177 DVD Recorder/HDD Recorder
LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Dec 01, 2007 | LG DV276 Recorder
LGDVB418 DVD Player Logo
61 people viewed this question
