Question about Frigidaire Electric Dryer
Just hook up dryer but can't get it to start - Frigidaire Electric Dryer
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Start up procedure
Check your vent duct, it may got clog inside there. Take off your vent duck from the rear of the dryer. Turn on the dryer again, if it is hot, your vent duct is the issue. Else, you need service man to take care of it.
Oct 07, 2013 | LG Dryers
Dryer electric was hooked up wrong ... netural witer was in the hot side of the recepital ... black hot was in the netural position. I hooked it up correctely but now dryer does not turn on at all. We...
Sounds like damage to motor or start switch on motor due to the cord wired incorrectly. You will more than likely have to replace the motor in the dryer.
Jan 01, 2011 | Whirlpool Dryers
The dryer runs but does not have any heat. I
Start by hooking each of the thermostat wires together to bypass . When dryer starts heating, you have located the defective one.
Nov 08, 2009 | Dryers
My dryer stopped heating up so I tried to fix the heating element. I noticed in the other one that some of the coiles broke in half so I knew this was the problem. Well I bought a new one, hooked it up and...
Could be a defective element, but it also could be your thermostats faulty...give them a check.
Normally you can only hook up the heating coils one way...I do not believe that would be the problem.
Hope this helps
Sep 29, 2009 | Whirlpool LEN2000PW Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Dryer gets hot to the touch
If you didn't install new venting I'd start by checking the vent hose from the back of the dryer to the outside vent hood to make sure there is no blocked airflow. Could be something else but that is where I'd look first. Good Luck.
Jan 15, 2009 | Frigidaire GLER331A Electric Dryer
Neptune dryer
there is no transformer in the dryer, i am guessing you have a 110 v motor and when you hooked the plug wrong, you could have supplied the motor with 220 v that's why you can smell something burnt.
the heater is 220 volts. regular dryer has dual voltage supply. 110 v and 220 volts.
tnx 4 using fixya,
drcool
Sep 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Washer doesn't work, dryer does- HELP!
  • check your breaker, one side of the 220v circuit breaker may have tripped causing only one of the units to work.
  •  turn your breaker off then back on.
Jun 28, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
Dryer Won't Start
use a isolated transformer and just hook up the wires that you think are positive and negative. isolated transformer is so that you do not get killed by a shock
Jun 26, 2008 | Frigidaire FGQ332ES Gas Dryer
Frigidaire  Electric Dryer Logo
29 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
