Question about Olympus MJU 400 Digital Camera
Orange lights flickers for up to 30 seconds on start up and after each picture is taken
  • 747 Answers
30 seconds is quite a long time for a camera on start up but I don't have the start up time specifications for this camera. Now for the orange light flickering after a shot the lights are telling your the pictures is being loaded to your memory card. It still seams like a long time to be loading a picture but I don't know where you has set the quality level of your photo's another thing is formatting the memory card. The memory card needs to be formatted to the camera it is being used in, if this card was not formatted I'm surprised it's working at all. My suggestion would be to download the pictures from the camera to your computer Hard Drive eject or safe disconnect the camera "drive" different computer call it different names. You must stop the card before removing the USB cable.
Once the pictures are on the computer hard drive then format the memory card this will clean all the pictures off the memory card and make it ready for new pictures.
Posted on Dec 30, 2010
Testimonial: "that was very helpful"
Wd-62628 status light solid orange
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 03, 2014 | Syntax LT30HV 30 in. HD-Ready LCD...
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
Canon lv-5220 multimedia projector flickering after start up
If it happens with no input hooked up then it could be the lamp. Or Worse.
Dec 05, 2012 | Canon LV-5220 Multimedia Projector
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    DS Nintendo Lite - will not turn on
    Sounds to me like you have a bad battery pack
    Jun 14, 2009 | Nintendo DS Lite Console
    Lcd quit working
    There is a 95% chance that your powerboard needs to be upgraded with a few newer-better components.
    I repair many gateway boards on ebay and this is a common occurence.
    There is also a slight chance that a bulb is weak and is causing that effect.
    If you unplug the vga cord while it is on, let it sit about 30 seconds till the power light turns to amber and then plug the vga cord back in you may get the desktop to flash on for a second or two.
    It would have to be taken apart and the boards looked at to get a better idea.
    If you do take it apart, send me a picture of the board to bammbamm@ptd.net. I may see a problem
    Fran
    Mar 29, 2009 | Computers & Internet
    Screen flickers for about 20-30 seconds sporadically
    Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
    Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
    DLP TV starts to loose picture after 1 - 1/2 hours of use
    This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
    Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
    Olympus MJU 400 Digital Camera Logo
    98 people viewed this question
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Steven Wander
    Steven Wander
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
