Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
No dispensing of water from container.
The water in canister is not dispensing. Cleaning fluid releases but no water dispenses when lever on handle is held down to do so.
    President:
  • 1,673 Answers
Check the bottom of the tank, there should be a gasket on the valve at the bottom of the tank. Must be on the tank and not sitting in the hole. Make sure the tank is sitting firmly and not off set even a little. Loosen the cap for the flow indictor while running, then tight when fluid starts leaking out, stop when the spinner starts spinning. Other then that you may have a clogged line somewhere.
Posted on Sep 18, 2008
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
How to fix clog on hoover floormate fh40010?
I was having the same issue with my NEW just out of box Hoover FH40010. First run on the floor was great then the water/cleaner stopped dispensing!!! I found that when is assembled it out of the box I did not have the handle "plugged-in" properly!! I reattached it to where there is NO gap in the handle when pushed firmly into place and locked in the base. WATER SOLUTION NOW WORKS PERFECTLY!!!
Nov 30, 2012 | Hoover FloorMate Hard Floor Cleaner -...
NO CLEANING SOLUTION IS DISPENSED WHEN i PULL THE HANDLE
the most common issue with the pro-heat not spraying is the heater being block up the link below is a video how to clean the unit.
http://www.youtube.com/watch?v=xNCEFwZzD1A&feature=related
Aug 18, 2012 | Bissell ProHeat Deep Cleaner Upright...
Water not dispensing
Check the release valve on bottom of clean water reservoir unscrew if needed, once again if your not sure run hot water in the solution tank through the system to help remove old soap residue and always run hot water through to prevent future problems after cleaning carpet and storing.steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
THE STAIR HANDLE WILL NOT SQUIRT WATER AND/CLEANING SOLUTION
The hose or nozzle could be plugged. The hose can be disconnected at the machine end there is a clip on the bottom of the connection. The fluid is dispensed by a pump which could be bad. If you disconnect the hose and put a rag at the opening to catch the fluid, then turn the machine on briefly the fluid should squirt out if the pump is working.
Nov 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have the Quick Steamer Plus 160 Series/2070 Powerbrush. It will not release cleaning solution and will not pick up solution that had already been dispensed. Is this something simple I can fix???
I checked the bottom of the fresh water supply container and all was well there then I used a pin in the tiny air valve on the container. Turned the machine on, pulled the lever to release water and held it for several minutes and finally the water started to release and the machine works fine now.
Aug 01, 2009 | Bissell 1960-3 QuickSteamer Plus Upright...
Bissell 9500 Proheat 2X won't dispense fluid.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fgjhdjk
Jun 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Solution does not dispense
The trigger that releases the water is connected by a piece of plastic inside the handle. This plastic tends to bend over time, so it won't press the plunger high enough. I brought it to a vac repair place for the same reason and they added an extension which made all the difference. If I were to do it myself next time, I would look to see if a metal rod were possible to take the place of the plastic. Maybe not, but it would be worth a look.
Nov 05, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Oct 20, 2008 | Bissell 9200 Upright Vacuum
Cleaning
Either you have a pinched or clogged water line, or the rod in the handle is pushing down like it should. The drw back is Bissell has deemed this unit and its parts obsolete. So any parts are hard to find.
Nov 04, 2007 | Bissell 1950-3 Quicksteamer Plus Vacuum
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
176 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
