Question about New Balance 1400 Treadmill
I accidentally pulled the emergency plug while working out. When I restarted I got an error #3. It flashed alternatively with the pulse button which doesn't work most of the time anyway. The next day I got all 8's displaying until I restarted. It seemed to run ok for that workout. Prior to the errors, I noticed that whenever I touch the back of the unit while changing speeds for intervals, I get a mild shock. That also happened when I held the left hand area. Do I have multiple issues or are they related? I am afraid to use it and do more damage if there is a problem, but need my daily run...
  • New Balance Master
  • 6,694 Answers
my be the motor isolation winding have some problem, or there is some moisture deposit inside the motor or the motor driving card. that's why u got shock. also check the ground wiring is proper or not. in my opinion as its create danger for u, contact the manufacturer for service.
ok
Posted on Dec 31, 2010
Problem, emergency screen accidentally turned on, won't go off, can't call out or receive calls
When you say "Emergency Screen", do you mean the dialer that you can access when your phone is behind the lockscreen? In that case, press the back button to exit. If you're restarting your device and are only able to make emergency calls, your SIM/RUIM card may be dislodged. Power down your device, remove it, and re-insert it before powering on again.
Jan 15, 2015 | T-Mobile My Touch Cell Phone
Torpedo FN-10195 Magnetic exercise bike ERROR E1
Contacy the makers to see what the error code means.
Jan 10, 2014 | Sport & Outdoor - Others
Doesn't Sense Pulse
Pulse is a selling feature on these machines...they dont work too well....I wouldnt be too concerned about pulse.
Jan 02, 2014 | Exercise & Fitness
Help have onix split system air con and remote not working and it s the only way to turn it on have tried every where to get one model no is TEM-84CHSBE heat unbearable in summer nth qld aust.
Auto-restart Presetting:
The appliance is preset as no auto-restart function by manufacture. If Auto-restart function is needed, follow the
step below to activate this function:
1) Make sure the Air-con's power is off:
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify.
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard.
The Auto-restart function is then activated. To cancel the Auto-restart function, repeat above procedure until four
Remarks: When remote controller is out of work, open the panel and you can see emergency button there, see the
The emergency button for 50, 70, 90 series is at the top right, see " ON/OFF " button there.
Auto-restart set:
the appliance is preset as no auto-restart function by manufacturer. If Auto-restart function is needed, follow the
below step to activate this function:
1) Make sure the Air-con's power is off .
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify .
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard, then Auto-restart
function is activated. To cancel the Auto-restart function, repeat above procedure until four short beeps are heard.
Oct 31, 2011 | Heating & Cooling
I have a Emerson DECT 6.0 with 3 head sets and i cant get the dial tone back from pulse.
It was easy for my Emerson Dect 6.0 to be switched either rotary / pulse by just pressing the "FLASH" button for 3 seconds until it beeped. Problem solved.
Or if that doesn't work, you have to:
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
• Press the MENU button. Select BASE using <FLASH - or - CID> and press the MENU button again.
• Using <FLASH - or - CID> select DIAL MODE and press the MENU button.
• Using <FLASH - or - CID> select TONE or PULSE and press the MENU button.
OR
Press and HOLD the "<FLASH" button for approximately 3 seconds. T (Tone) or P (Pulse) appears in the display.
Feb 12, 2010 | Uniden DECT 6.0 Cordless Telephone...
Cowno D2+ 2.11 freeze
there's a reset button near usb port.
Dec 30, 2009 | Cowon Systems Cowon D2+ 16 GB MP3 Player ...
Error after pulling out paper drawer during printing
The error button is probably flashing because there is paper in the printer that did not feed through. or just power off the printer and power back on and see if that helps
Dec 18, 2008 | Brother HL 5250DN Laser Printer
SERVICE ERROR 6000
Use this:
1. Turn off printer
2. Hold down Resume button and press Power button
3. Keep holding down Power button and let Resume button go
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more
8. Your printer should respond as normal.
May 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Error 5100
Hello! Try this:
1. Unplug the power cord
2. While pressing the ON button, plug the power cord back in.
The power light should flash an orange/yellow color.
Continue pressing the ON button, and press the RESUME button 4 times. The light changes every time you press it.
3. Release both buttons, and restart the printer.
The printer should now stop blinking and operate as usual.
I hope this works for you. OMS
Apr 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Virgin Pulse model VP-07 CD clock radio
1. To set the clock to leave the unit in standby mode. (Plug in the AC cord to a wall outlet without switching unit on). 2. Press SET button for about five seconds until AM--12:00-- stops flashing. 3. Press down TUNING button to adjust hour, and up TUNING button to adjust minute. 4. Press SET button to confirm time set.
Sep 11, 2007 | Virgin Pulse VP-07 Clock Radio
New Balance 1400 Treadmill Logo
111 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
