Question about Watches
Tag Heurer watch manual for WAF2011.BA0818 Aquaracer
  • 203 Answers
SOURCE: Remove Links from Tag WAF1416.BA0813 Watch
yep try that there are a couple of different styles if it wont move it could be a screw . if this helps please rate me
Posted on Nov 22, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
escapement
  • 2334 Answers
SOURCE: My TAG Aquaracer bezel moves counterclockwise
Yes, there are solution for that, but you will not be able to solve it yourself as the new part is needed.
That new part is called BEZEL SPRING and it is fitted underneath the bezel.
Bezel spring has special hooks pressed into it and allows to turn the bezel one way only (anticlockwise), at the same time stopping the bezel to turn clockwise.
Another cause can be that the dirt and grime are collected between the bezel and the watch case (this is where the bezel spring is located) and is stopping functionality of the bezel spring by leting the bezel slide over the hooks. This can be fixed by cleaning the watch case in ultrasonic cleaner.
Anyway- if the bezel is rotating on its own, I suggest that the bezel spring is broke and you will need to replace it.
Do not forget to rate, please.
Posted on Feb 10, 2009
  • 11 Answers
SOURCE: Dont know how many time to wind it
until it begins to feel just slightly taunt,Do NOT over wind a wind-up wrist watch, if its a self winding you should just have to walk in it to wind it. here is a link to a pdf of your manual which has winding procedures, Good luck Jon click here
Posted on May 21, 2009
escapement
  • 2334 Answers
SOURCE: How to adjust the steel band on my Tag Heuer
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
Tip
TAG HEUER Aquaracer quartz chronograph manual.
Follow this link and download original TAG HEUER Aquaracer quartz chronograph manual: http://www.tagheuer.com/the-collection/aquaracer/man/quartz-chronograph/index.lbl?w=CAF1110.BA0804
on Feb 09, 2010 | Watches
I need an instruction manual for a Tag Heuer 50 Chronograph Aquaracer mens watch
Tag Heuer recognizes manuals by watch caliber number, not the watch model. Browse through my Tips and Tricks. There are few Tag Heuer watch manuals. Check out if this can help you.
Feb 24, 2011 | Watches
How to use Chronometer watch
Go to http://www.tagheuer.com/the-collection/aquaracer/man/calibre-s-chronograph/index.lbl?w=CAF7110.BA0803 and you will see your watch? and on the right is a menu with "user manual" in it. Down load the manual.
Aug 18, 2010 | Tag Heuer 2000 Aquaracer Chronograph...
Battery Charge Life 10 years ago, not being able to afford a real TAG, I purchased a 'replica' Aquaracer Automatic in Bali. I am happy to say that I am now the proud owner of a real Aquaracer Automatic....
If you go to http://ww2.tagheuer.com/_documents/manuals/EI2246_en.pdf
you should arrive at the user manual for a Tag automatic watch which is similar to yours (an Aquaracer).
You will see that they claim 38 hour running when fully wound.
In view of the very small forces involved and the variations that occur in the manufacturing of the mechanism, I don't think that you should be surprised if there is a variation in running time.
If your genuine watch runs for a significantly less time thean they claim, you may have a reason to complain.
May 29, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
Manual tag chronotimer
This is the owners manual for the Formula 1 ChronoTimer.
http://ww2.tagheuer.com/_documents/manuals/EI2291_en.pdf
Sep 16, 2009 | Tag Heuer 2000 Aquaracer Chronograph...
May 21, 2009 | Tag Heuer Aquaracer Chrono Automatic...
Need instruction booklet for Tag Heuer Classic Chronograph 2000
PDF Manuals at Normal 0 0 1 2 14 1 1 17 11.1282 0 0 0 www.tagheuer.com
Do a search for Tag Heurer manuals
Mar 29, 2009 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
I am unable to return to the 0 crown Position - TAG-CAF2112
The aquaracer has a 'screw-down' crown.  This means that the crown needs to be screwed in the reset it back to the 0 position.
Jan 09, 2009 | Tag Heuer Aquaracer CAF2112.BA0809 Wrist...
Watches Logo
29 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
