Question about HP Computers & Internet
Osd lock out comes up when I push auto on monitor to set brightness ,or push any buttons to set manualy.Screen too bright
  • 3 more comments
  • gmarshall300 Dec 30, 2010
    B41A5 : Hewlett Packard
    HP serial number is CHD 7220v0b model number Model 1740 Regulatory Model No HSTND-2121-F
    Monitor Hewlett Packard Model L1740 Serial No CHD 7220V0B Regulatory Model No HSTND-2121-F
    THANK YOU WORKS A TREAT
  • gmarshall300 Dec 31, 2010
    Not at this time thank you.All is good,many thanks
  • gmarshall300 Jan 01, 2011
    all's sweet thanks very much
  • HP Master
  • 13,433 Answers
Hello, you need to post the brand and model of your MONITOR atleast if you expect to get assistance.
Posted on Dec 30, 2010
  • 4 more comments
  • Ekse Dec 30, 2010
  • Ekse Dec 30, 2010
    OSD LOCK - The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. if the OSD is locked - as it is in your case. PRESS AND HOLD THE MENU BUTTON FOR 10 SECONDS TO UNLOCK THE OSD.
    then you can use the buttons on the computer again normally.
  • Ekse Dec 30, 2010
    UNLOCK THE OSD.
  • Ekse Dec 30, 2010
    UNLOCK THE OSD.
  • Ekse Dec 30, 2010
    anything else I can help you with?
  • Ekse Dec 31, 2010
    if I solved your problem why have you indicated that I did not solve the problem? Please accept my solution.
  • HP Master
  • 4,924 Answers
If the On screen display is locked..press and hold for ten seconds the menu button ..and will unlock itself.. This is just a protection for to keep the settings
Posted on Dec 31, 2010
  • Catalin Turcu
    Catalin Turcu Dec 31, 2010
    Click settings button,
    Go down to OSD settings then hit select, and go to OSD Lock and select,
    Minus (Negative) To Disable
    Plus (Positive) To Enable
    this in case it has the lock on the menu
How do you adjust brightness on a Gateway ZX4971. There are no buttons on the monitor.
My Gateway monitor instructions refer to buttons located on the right side. The procedure calls for pressing the Auto button first to set the display image for the current screen resolution then pressing the Menu button to open the on-screen display (OSD) menu. You can move through the OSD menu to select parameters such as Picture (brightness).
Dec 18, 2014 | Gateway Computers & Internet
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
My brightness menu is locked on the screen and my monitor buttons aren't working .. I'm having a silver Samsung Syncmaster 720N.
OSD Lock & Unlock
When pressing the AUTO button after locking the OSD
When pressing the MENU button after locking the OSD
This is the function that locks the OSD in order to keep the current states of settings or prevent others
from adjusting the current settings.
Lock : Hold down the MENU button for more than five (5) seconds to activate the OSD adjustment
lock function.
Unlock : Hold down the MENU button for more than five (5) seconds to deactivate the OSD adjustment
lock function.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 10, 2011 | Samsung SyncMaster 720N Monitor
My optiquest Q19wb monitor has the contrast/brightness option disabled in the menu..I am using it as my secondary monitor..OS used is win7
Try unlocking it:
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
Apr 16, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
How do I adjust the brightness on LG W2053tp
Look for the buttons, enter menu and the Brightness setting then use + or > to go up
Mar 07, 2011 | LG Flatron F700P 17" CRT Monitor
Adjust screen brightness
Press the OSD ("On Screen Display") button on the bottom-front of the monitor. Use the other nearby buttons to "navigate" through all the settings, to select "Brightness", and to move the level UP/DOWN.
Wait a few seconds, and the OSD will vanish, by itself.
May 13, 2010 | LG Flatron L1750S 17" LCD Monitor
I'm tring to restore original settings on my LG monitor and keep getting "osd lock" message. Half my monitor is very bright, the other half it 10-15 shades darker.
I held the "Menu" button down for 15 sec. and it unlocked. Then used the Auto Set feature. It didn't work immediately on the two-towned
screen, but corrected itself within 1/2 hr.
Thank you.
Feb 08, 2010 | LG 22" FLATRON LCD Monitor
My LG Flatron Wide Monitor is set for 100% bright, which washes out the image. How can I adjust the brightness? L204WT
Does this monitor have an OSD (On Screen Display),
and a button to activate the OSD?
Does the OSD have the capability to adjust the brightness?
Oct 29, 2009 | Computers & Internet
OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Aug 28, 2007 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
