Question about LG WM-1832C Front Load Washer
Drain pump on my LG wm1832cw seems to be "clogged" I've cleaned drain filter check discharge hose and have made sure house drain is clear.
  • porsche917 Dec 14, 2008
    will not drain how do you access the pump to disassemble pump and where and how do you remove pump?
  • Anonymous Mar 27, 2014
    The mechine is not draining again
    Welcome Back:
    Visited the website for 2 consecutive days.
I took the pump out . then took the pump apart , water got past the o ring , where shaft goes into the center. i cleaned out the sludge & put grease on the o rings before putting it back together. it's worked since,
Posted on Nov 30, 2008
LG MD-10655TP Washing machine EO error
This error or fault code indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Feb 22, 2016 | LG Washing Machines
What causes the EO error message
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Oct 04, 2014 | LG Washing Machines
I have wm1814cw lg front loader washing machine with oe light on and not draining we have clean filter unclogged drain hose and reset by unplugging and holding down power putton and start button als
Sep 16, 2014 | LG Washing Machines
What is wrong when the code oe shows
This OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Sep 08, 2014 | LG Dishwashers
OE ERROR CODE
The manufacturer has assigned the OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Jul 08, 2014 | LG Dishwashers
What is Oe error lg model lds5540st
The OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Jul 04, 2014 | LG LDF7561ST
LG trom wASHER wm20160W WONT DRAIN
Start by getting to the drain on the pump there should be a hose hooked to the pump and there may be a filter that u can clean out. Check the pipe and make sure it is clear and also check the discharge hose to be sure it is clear as well. By the way do u hear the pump come on or try to. If lines are clear and the pump is running then you most likely have a bad pump,
Apr 20, 2014 | LG WM1814CW Front Load Washer
Our LG Tromm WM1814CW frontload washer is not draining in the spin cycle, but its only sometimes. We have tried cleaning the Filter and its clear, we looked in where the filter is to see if its clogged,...
hi Shellinator7.
check the small drain hose on the side of the pump that is clogged, then that is not a failure that will significantly affect the normal operation of the washer. If your washer is not draining okay and you don't mind catching some water that spills out of that pump filter area when you open it up, then you don't necessarily need to remove that front panel and bother with unclogging that small drain hose. If the large hose between the tub and the pump or the discharge hose between the pump and the house drain behind the washer is clogged, then you may need to open up that cabinet.
you could also check out this link and read up some more on this.
LG Tromm front load washer not draining in the spin cycle Google Search
Dec 14, 2017 | LG WM1814CW Front Load Washer
I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
May 31, 2010 | LG WM-1832C Front Load Washer
LG WM1832CW Front Load Washer
FE means water is overflowing. Check pump filter. Check water level switch and hose. Also check that drain hose isn't too low causing it to refill itself continuously. In any case the drain pump should run for 4 minutes to try and eliminate the extra fill
Dec 28, 2007 | LG WM-2277HW Front Load Washer
LG WM-1832C Front Load Washer Logo
502 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
