Question about Mantis Tiller
Mantis electric tiller Power at plug, no power to motor. Suspect circuit breaker. Is it possible to remove circuit breaker without opening housing? HOW?
  • 398 Answers
SOURCE: Pull cord stuck
it sounds like the recoil spring in the "housing" is jammed( or something is broken) youll have to take this apart without breaking it. you may have internal engine damage if it was unusually hot and the pullcord jammed. try using a richer oil mixture for fuel also if you fix the pullcord. hope this helps, keep me posted.
Posted on Apr 24, 2009
SOURCE: Would like to know what year this tiller would be.
replace primer bulb. If that's not the problem check the float in the carb for pin holes . check fuel lines and intake line
Posted on May 17, 2009
SOURCE: trouble starting old Mantis tiller 9012 - don't have a manuel -
Mantis has the owners manuals in pdf format available for download on its website. The tillers are here (I hope the link to the tiller group works...if not, just go to the main site and look for "owners manuals" link.
Also, you can call a number and get a representative who usually can help at the numbers listed there, find authorized service people if its not something you can do yourself, order parts and find detailed schematics in the owners manuals. My dog actually ate mine. LOL. But they are free, the owners manuals, unlike other places that charge you for them like they were a "part".
http://mantis.com/owners_manual_library-swell2_tiller_engine.asp?cat=8
Posted on May 18, 2009
SOURCE: My Mantis Tiller 4cycle engine
I had same issue with my 2 year old 4cycle. Check if the carb is moving full stroke with throttle movement. I had almost no movement at carb at full throttle, found the trigger in throttle handle was cracked and bent rather than pull cable. I called mantis and they promptly sent a new handle bar ***'y with new cable, throttle ***'y Etc and that solved my problem.
BTW: If you cannot wait, I did figure out that if I pushed the carb to open with the throttle trigger fully pulled it would run at high, but when you let go.....LOL
Rich in Wethersfield, Ct
Posted on May 28, 2009
SOURCE: Tine shaft removal for mantis 2 cycle tiller
Put the tiller in a vise clamping on the bottom of worm gear housing. Remove worm gear housing cover. Clamp the worm gear at the top with a vise grip (I think Kuya Jon is correct in that you could skip this step because the transmission won't move when unscrewing, but I did it anyway just in case). Put a pipe wrench on the left tine shaft and unscrew it like it was a normal bolt. It's in there tight and it will take some force. When I unscrewed mine, the left bearing seal retainer, left bearing seal, and left bearing all came out with it. I just needed to replace the seals. I went to the right side, and with a screw driver carefully pried out the retainer. Then it's easy to just pull out the right seal with your finger. Put a new right seal in and insert the right retainer. Make sure the retainer is facing the correct way. I used a block of wood to tap mine in once I had it positioned because I was afraid to hit the retainer with a hammer. Now I put the tine shaft back in while holding the worm gear with the vise grip. Screw the shaft as far as it will go by hand and then go the rest of the way with a pipe wrench. Now came the tricky part. The right bearing did not slide right in. There was some resistance. I had to use a 1/2" threaded pvc pipe (not sure it needs to be threaded but that's what worked for me) longer than the tine shaft that was sticking out. I slip the pipe over the shaft against the bearing and tapped with a hammer. This drove the bearing in all the way. It needs to go in far enough to leave room for the seal and retainer. The plastic pvc allowed for this. Now put the right seal in. If the outer edge of the seal is only flush with the housing you did not tap the bearing in far enough. I made this mistake on my first try and tried to force the retainer in. Take it from me. It won't work. You will end up ordering another retainer to replace the one you mangled. Once in properly I slid the retainer over the shaft and then put a washer over that to tap against. The block of wood doesn't work on this side because the shaft is in the way. I used my pvc pipe again to tap against the washer and, wala, it worked like a charm. I hope this helps someone. All the other posts really helped me. Thanks!
Posted on May 21, 2010
Mantis electric tiller runs for about 20 seconds then cuts out. Hit circuit breaker, runs then cuts out again and smells like it's burning. Went through all the troubleshooting and no warranty. Help!
It probably smells like it is burning because that is exactly what is happening. Persisting is likely to make things worse, if it is possible for things to be worse.
As the circuit breaker is tripping it is likely the fault is electrical. There probably isn't much electrical to go wrong apart from the motor, a switch and some wiring. A motor fault would seem likely unless the mechanical drive is so very tight it is overloading the motor.
Clearly the machine must be dismantled and checked through by someone competent to do so. The supplied troubleshooting guide is not likely to be much help as they have to be safety-conscious, they tend only to deal with external issues.
Jun 23, 2016 | Mantis Garden
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I have a Mantis Tiller. It starts but has no torq...
possibly the (muffler) is plugged with carbon. happens when too much oil is used
May 19, 2010 | Mantis Tiller
I have a mantis tiller, the tines won't turn, the engine IS seated to the flange. any ideas on a fix?
If the motor rpms up without drag it might be a bad gear in the transfer case or a broken cable if it's a cable drive, could also be a bad or stuck clutch. Hope this helps
Apr 27, 2010 | Mantis Tiller Tines #1622 00 02
We have a Mantis electric cultivator that won't start. it's only a couple of years old
Electric tiller, and it will not run ?
I would check the cord that you plug into.
You must remove the plastic housing, by removing the screws.
Next look at the plug, is it in good shape, has anything been pulled out of it ?
The motor brushes should also be inspected.
Please let us know, we repair all Mantis equipment.
Jan 27, 2010 | Mantis Electric Mini Tiller/Cultivator
Trouble starting old Mantis tiller 9012 - don't have a manuel -
May 16, 2009 | Mantis Tiller
What type of tiller
# Gas vs. Electric * Some smaller models are electric. o Limited range based on length of extension cord. o Electric doesn't have the same amount of power as a gas-powered motor. * Most of the larger models are gas-powered. o Gas-powered machines are more powerful. o Keep in mind that gas-powered machines require more maintenance, including refueling, engine fluid changes and refills, and winterizing in cold climates.
Aug 27, 2008 | Mantis Tiller
Mantis Tiller Logo
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
