Question about Refrigerators
Water does not go into defrosting pan, it runs down the inside back of the refrigerator during the defrost cycle.
  • 2,382 Answers
Hi, if your refrigerator leaks water in the fresh food section, there are two ways this can happen.
The most common cause is a blocked defrost drain. Every 8 hours or so, the refrigerator goes into defrost, and ice is melted from the cooling coils. This water must drop into a very small hole just under the evaporator coil, and from there, falls into a drain cup in the fresh food section. It the goes into a drain hose thru the back wall and down to the condensate pan under the fridge.
To correct a blocked drain, remove the inside panel in the freezer to expose the evaporator, then use very hot water to melt any ice you see down in the drain area below the coils. Sometimes a small probe, such as a coat-hanger which has been cut to 6", may be used to help clear the small hole. Always add a capful of bleach to the hole once it is clear to kill any residual algae.
Posted on Dec 30, 2010
Why does drip pan fill up
Hi
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | KitchenAid KSRA25CNSS Side by Side...
My water dispencer is driping water how would i fix that?
Hello, Self- defrosting refrigerators disposed of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan water normally evaporate. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment, then the water build up at the bottom, inside of the refrigerator. When the water has build up for a time it may spill out of the front of the door opening. To fix this problem, Clear the drain tube or channel and allow the defrost water to flow down to drain pan.
Thanks
Jun 21, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice maker not make ice, leaking water
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 30, 2010 | Maytag MFF2558KE
Water leaks in freezer, and then defrosts and leaks on floor
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 28, 2010 | Jenn-Air JCD2389G Side by Side...
We have a leak inside of the refrigerator. Water
Mar 20, 2010 | Refrigerators
Water leaking from the bottom
Jul 16, 2009 | Refrigerators
Water collects on the bottom of the refrigerator
Jul 11, 2009 | Refrigerators
Water dripping inside refrigerator
Jul 07, 2009 | Refrigerators
Water accumulating under the vegetable boxes in the refrigerators
Jul 06, 2009 | Refrigerators
Water dipping on the inside of fridge towards back
Hi
Please do rate this solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 26, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
