Computers & Internet Logo
Posted on Dec 30, 2010
I have sound distortion. When I loaded my EZ Vinyl Tape Converter on windows vista I had to go on line for a patch or fix..that worked..but now i have windows 7 and have the same distortin and cannot find a patch or fix to get my ez compatable with windows 7.please help
5 Related Answers
GentGolfer
"Doc"
  • 8 Answers
  • Posted on Mar 02, 2009
SOURCE: EZ CAM 368 not working With Vista
Open the install CD using explorer.
Right click and make a copy of the drivers folder.
Open My Documents and paste the folder.
Rename the folder by adding (EZCam Drivers), including the parentheses after the folder name.
Unplug and Uninstall the webcam
Reboot pc ... do not plug in the cam
When reboot is complete, plug in the cam. New Hardware wizare should launch.
When asked for location of drivers, specify the folder you pasted into My Documents
Anonymous
  • 13 Answers
  • Posted on Oct 22, 2009
SOURCE: I would like to transfer music from a cassette to
Even simpler than that program is Audacity. You can download it free. The easiest way to accomplish what you want to do is this. Go to WalMart and buy a double male ended headphone cord for about $5 Plug one end into the headphone jack on the tape deck, plug the other end into your microphone jack on your computer. Be sure to turn down the volume to about 10% on the tape deck. This will keep the sound from becoming destorted. Press record on Audacity and start the tape. You can see it record as it plays. Then save that Sound file as the name of the song.
Anonymous
  • 33 Answers
  • Posted on Jan 13, 2010
SOURCE: Aspire 5613.Loaded windows 7 over
Uninstall the Acer Empowerment Tray.
Anonymous
  • Posted on Jul 25, 2010
SOURCE: Up graded system to windows 7 sound now distorted.
I had same problem, this is what solved it! Go to www.ionaudio.com/ezvc Download/install software for windows7. Then print setup instructions, follow instructions and your sorted.
Anonymous
  • 5 Answers
  • Posted on Dec 26, 2010
SOURCE: The EZ Vinyl/Tape Converter software seems to have
It is probably too late to help you, but others might have this problem and we solved the issue by disabling and enabling.
Click on windows button (bottom left hand corner), control panel - sound - Playback tab
You will find that there are a number of different speaker setups in that area. One set will have the light meter moving, but there won't be sound from your speakers. This is because the modern computer is much more like an amp and has the ability to have different speaker combinations and settings. You only use one speaker set-up.
- double click on a speaker option, advanced tab, and test. If there is no sound, then your speakers aren't connected to that port. Move to the next one.
- Once you find the correct speaker setup for your system, then disable the previous setup and ensure this one is enabled. Once the meter bar lights up for the right speaker combo, all sound will work as expected on your computer.
The modern computer is much like a stereo amp now, and you have to tell it which set to use. (For some reason it works well enough, until you start adding stereo components onto your system.)
Hello, Since downloading iTunes version 11.05,
You might need to either reinstall the EZ or see if there is an update.
2answers
Ez vinyl converter
Yes it's painful... Manufactures and vendors FIX the items that have THE MOST complaints, but often build in NEW problems with devices that worked before!
TRY going back to a older version(s) first... ESPECIALLY true if your device worked BEFORE the latest update... HERE is a GREAT Site for you and others:
Old and New Software Version Downloads OldApps com
IF you need a older version of X program... you should find it there!
Anthony
Numark PT-01 USB Portable Turntable EZ Vinyl/Tape Converter
Pull an old iTunes itl. Lib file from one of your older backups and use that to replace the newer iTunes itl. file
4helpful
2answers
Up graded system to windows 7 sound now distorted. Both sound monitors way in to the red zone as though to much audio coming from record player. How do you reduce this level. EZ vinyl converter
I am having a problem recording more than 1 track on my new ION tape express cassette conversion system. I was instructed by ION to uninstall the previous ez vinyl converter software and re-install the new...
I have the same problem and do not know the answer. Was searching here for an answer to my problem. Only a small part, 4 tracks in fact, about 5 minutes from a 30 minutes tape are imported to Itunes. where is the solution because it seemed the computer was recording the whole tape without problem. Where is the data gone. Can someone explain. Nico
I would like to transfer music from a cassette to my laptop. How do I do this using EZ Vinyl/Tape converter? Thanks
9helpful
9answers
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
1helpful
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
36helpful
3answers
Need drivers for my ION Audio USB Turntable
Hello
USB audio turntable can be found on this site: Driver Update. have a nice day
11helpful
4answers
EZ Vinyl Converter produces file that doesn't work
Try
Control panel
-Sounds - click on Speech and Audio Devices -
Click onSounds and Audio Devices. or if your in classic view -double click.
Click on Audio tab
Make sure that thedefault devicefor Sound Playback is set to the device hooked up to the speakers
i.e. set it to something other than the USB AUDIO CODEC which is the turntable
Grand Canyon Tech
Grand Canyon Tech
