Question about Whirlpool Dryers
LFE7800WL will not start just hum when you press the start swithh
  • 312 Answers
The Hum most commonly means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 put your hand inside the drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good. You may be looking at motor problems.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
Hope this helps,
Best Regards,
Mark
http://www.fixya.com/support/t6322596-get
Posted on Dec 30, 2010
  • 132 Answers
The belt has probably come off !!
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
When statrting the dryer it doesn't start but hums
Sounds like a bad motor to me. If you hold down the start button and hums while its pressed its the motor. Depending on how old it is should determine your decision of whether or not to have it fixed. Hope this helps...
Nov 28, 2009 | Coffee Makers & Espresso Machines
Kenmore dryer model # 110. 79902890 press the
you have a problem with a component called a capacitor.the capacitor stores an electric charge.this charge gives the motor the "kick" needs to start.if you have a faulty one the motor will hum because it cant turn.it should only be replaced by a competent appliance technician.
Oct 07, 2009 | Dryers
Start Button Hums when Pushed
Your contactor is getting weak. Try bouncing the front of the machine once or twice while it hums. If that works you'll need a new contactor. Do not let the humming go on for to long it could becme a fire hazard.Shut the machine off right away if you hear it.
Sep 02, 2009 | Kenmore 63942 Dryer
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Power off randomly. Battery in good shape
maybe you have an problem on the upgrade. an error. or a virus
downgrade that
May 21, 2009 | RIM BlackBerry 8800
Not enough water to do a wash!!!!!
Have you checked for a blockage in the pipe leading to the pressure switch? Normally a clear plastic pipe leading from the bottom of the drum up to a saucer shsped diaphram switch, also check the swithh by blowing gently into the input, does it click? Check with a multimeter.
May 08, 2009 | Washing Machines
Humming noise when i press the start putton
When I push the start button it would hum if I hold the button to long and then it would cut off.
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
