Question about Miele S544 Artico Bagged Canister Vacuum
My telescopic wand won't stay locked in any one position. Every time I extend it, it collapses as soon as I start using it.
5 Suggested Answers
SmartAlec
  • 171 Answers
SOURCE: The telescopic wand on my Miele S5281 keeps collapsing, how can I fix it so it locks in place.
Hi There,
You can get a button repair kit and it should fix your problem which is normally a loose spring. In Australia VacuumSpot sell these over the net.
Posted on Jun 14, 2012
chrispurs1
  • 372 Answers
SOURCE: Hose Collapses When I Try to Use Wand
Hi Both.
Ok you have A blockage, Remove flexi hose completly from rear of machine & completly remove wand & handle from the hose.
Now check flexi hose for obstruction if none present move on to the wand & hanndle look down through tha wand for any obstruction look very carefully where the plastic handle meets alloy tube there is A slight bend here often A coin gets stuck here & flips accross to block oppening when you try to use wand.
If you cant see anything coin etc put hose back on machine & switch on there should be good suction from the flexi hose,
Now with machine still switched on push alloy pipe back on if the hose suddenly pulls back & there is poor or no suction you definately have A coin stuck at the bend.
You will need A broom handle or other long solid pole to hit it out.
http://dysonmanuals.llc.nu/
Posted on Aug 06, 2008
  • 2976 Answers
SOURCE: Attachment hose collapses when using wand
The thoe or the wand is clogged. Remove the hose at the machine end, reverse it and turn the machine on. This should **** the blockage out, the way it got in. If you hear the motor straining, it's still clogged. I've already taped a small hook, like a screen door hook onto a broomstixk and fished into the blockage to remove it. Be carefol. If you puncture the hose by pulling too hard, the hose will be ruined. Tahe your time and look for something unecpected, like a toothpick or a LEGO piece. They and vacuum cleaner friendly.
Posted on May 25, 2009
  • 175 Answers
SOURCE: My telescopic wand height adjustment won't lock
These wands have a very small nub that locks them into place. They wear out very easily. You might have to replace the wand.
Posted on Nov 28, 2009
How to return telescopic reach pole to original position
Hi there, it's Jack at Dyson.
Once you've reattached the wand to the machine, you need to press the release catch again to collapse the wand back down inside the hose. The release catch is the same one you used to remove the wand initially, located just above the on/off switch.
I hope this helps, but if you'd like any further advice you're welcome to get in touch directly. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 12, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
The telescoping wand on my Dyson DC 25 will not retract back into the hose.
Hi Nina, it's Jack at Dyson.
Difficulty collapsing the wand can mean that the plastic handgrip section hasn't been correctly placed on the machine. When you replace the wand on the machine, make sure the handgrip section clips onto the main body and is down as far as it will go.
It's also a good idea to make sure that the hose isn't twisted, as a twisted hose can create resistance as you try to collapse the wand. Remove the wand again and allow the hose to untwist itself fully before attempting to replace the wand on the machine.
I'm confident these steps should resolve the issue, but if you would like some further guidance after you've given this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 20, 2014 | Dyson DC-25 Lifetime Washable & Reusable...
Dyson telescopic wand won't go back in (model dc14
take the wand off from the bottom and untwist it
May 25, 2013 | Vacuums
Hi There,
Jun 12, 2012 | Miele S5281 Callisto Bagged Canister...
Unable to pull the telescopic wand out - something holds it in place.
Hi Jane,
I'm sorry to hear you're having difficulties with your DC17. If the wand seems to be jammed in place, I'd encourage you to get in touch with us directly, as we'll be able to talk you through the process of freeing it over the phone.
You can call us on 1-866-693-9766 - or if you email your contact details to askdysonUS@dyson.com, someone will be in touch as soon as possible to provide assistance.
We'll look forward to helping you resolve this.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 27, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hdc11 i cannot close telescopic wandow do i close telescopic wand
I'm sorry to hear you're having difficulty collapsing your DC11's telescopic wand. It should retract in one smooth action when you hold down the catch - if it seems to be jammed, it's probably best if you get in touch with us directly. One of our experts will be able to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Sep 23, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Wand in stowaway dyson is hard to extend. Seems like u have to pull 3 clips from grooves in 3 rings around wand to extend and shorten wand which is a struggle
Hi there, you should just be able to hold the telescopic wand in one hand, press the button and pull the whole length of the wand out to its fullest position.
If the telescopic wand on your particular Dyosn is very stiff, you may need a replacement.
Your machine may still be under guarantee or warranty. If this is the case, please contact Dyson directly on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Dec 27, 2009 | Dyson "Stowaway" Canister Vacuum Vacuum
My telescopic wand height adjustment won't lock the height in place. The wand extends to full height with no locking in place. How do I fix it?
Nov 28, 2009 | Euro-Pro NV31 Infinity Vacuum
Euro pro shark 724
I'm not sure what "jammed shut" means, but I am assuming it means that it is collapsed in the short position and will not extend. What I would try, is to grip the lower end in a vise or something that will hold it securely and while pressing on the lock button, wiggle and pull on the top. Failing that, I would take a pair of large pliers and open them to fit loosly against the top pipe where it meets the lower pipe and while pressing the lock button, take a hammer and GENTLY tap the pliers to dislodge the mechanism. The pliers would be positioned against the top pipe and the taping should push the pipe away from the lower portion, the lower being held securely. Don't hit the pliers to hard or you will damage and mushroon the top pipe. If this doesn't work, you can take it to a repair shop for them to try or replace the wand assy.
Jan 26, 2008 | Euro-Pro EP724 Bagless Canister Cyclonic...
Miele S544 Artico Bagged Canister Vacuum Logo
422 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
